Old 09-14-2011, 12:19 AM   #1
treveiger
treveiger's Avatar
Is this clutch pedal rod suppose to be bent?
Here's a pic, I'm wondering if this is correct an can be adjusted or is it not suppose to be bent?
Thanks guys.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-14-2011, 02:55 AM   #2
John Pasinski
John Pasinski's Avatar
Re: Is this clutch pedal rod suppose to be bent?
Sorry I can't help with a better answer than this. Mine is like that also. It too is rubbing along the firewall hole. It got so bad, that it began to wear the rod, and the firewall. Made me so crazy I swapped out the bell crank w/ one I found at the junkyard that had an offset arm. When I connected the clutch rod, it brought more into the center of the firewall hole. Sorry I can't be more helpfull.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 09-14-2011, 07:41 AM   #3
I do not remember mine being bent when I took it apart, but that was many years ago..
Palf70Step is online now   Reply With Quote
Old 09-14-2011, 12:33 PM   #4
treveiger
treveiger's Avatar
Hey no problem guys, I'm just wondering if I can heat it up an straighten it up of will that hurt it.
Old 09-14-2011, 01:12 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
IIRC, I6 clutch rods have very slight bend. V8 rods have a pretty good bend to them after they exit the cab. I'm going to guess you have a I6 rod turned into a v8
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-14-2011, 01:14 PM   #6
faribran
i tend to agree with USMCCHEVY.... i have one of each at home.. i will take a look this eve.
faribran is offline   Reply With Quote
Old 09-14-2011, 04:16 PM   #7
treveiger
treveiger's Avatar
My trucks a v8, do I just switch the rod out?
Old 09-14-2011, 05:33 PM   #8
rsavage
rsavage's Avatar
This is what a V8 clutch rod looks like.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-14-2011, 05:39 PM   #9
lil hoodlum
lil hoodlum's Avatar
Yep! Looks like mine. You might try "flipping" it. Put the end that is currently on the bell crank/ Z-bar and flip it to where it is now on the clutch pedal arm/shaft. I have tried mine like that as well. I have 3 of them that I have pulled from the junk yard. All of the them have some serious wear issues. Some actually fit better backwards. My current one in my truck is also rubbing a hole into my firewall. I just keep putting some grease on it just so I don't hafta hear the grinding noise.
I would love to get a brand new one. I bought one years ago from LMC but it is a straight one. No curve to it.
Keith
lil hoodlum is offline   Reply With Quote
Old 09-14-2011, 10:03 PM   #10
treveiger
treveiger's Avatar
So I have a 6cylinder model?
Old 03-25-2012, 02:12 AM   #11
treveiger
treveiger's Avatar
Would a clutch rod from a 73 up work?
Old 03-26-2012, 11:23 AM   #12
67c10rustbuket
67c10rustbuket's Avatar
idk but I just removed my clutch assembly if you want it, 67 original 283/3ott. I'll look at it this eve to see how much bend it has and the condition.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
