1964 steering wheel bearings
After taking 3 month break and I just got my truck running with power steering on a I6/350thm.
Problem: the original steering wheel's bearing are bad and the wheel moves up/down alittle. Are there kits to rebuilt these steering wheel??????????????????? |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 1964 steering wheel bearings
for the 64-66, the bearing is replaceable, contact one of the supporting vendors or I use Classic Parts.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
The gm number that goes in the turn signal switch is 5679205,or you can get a new switch which willthen come with a bearing.your local dealer can still get that bearing no problem.
