![]() Join Date: Feb 2011
I found a 1994 chevy 350 want to know if it would go into my 68 1/2 ton long bed if it don't how do Make it fit
72 chevrolet 4wd 350/350 swb fleet green mean army machine ![]() Last edited by 1972hays; 09-14-2011 at 02:17 PM. |
Re: Help putting 94 350 I'm my 68 will it fit and the tranmison fit
yes it will fit...to make it work is going to depend on what route you go with the build...
Ok what's the route you would do and how
72 chevrolet 4wd 350/350 swb fleet green mean army machine ![]() |
I just put a 94 ' tbi350/4l80E into my Burb.I had to use 73-8? motor mounts and perches since I kept the stock exhaust manifolds on the motor.Check out my Burb thread for pics to see what I mean.It fits very well imo.Hope this helps,be good
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
thanks that helped a lot know i got some thinking to do
tyler tyler tyler..... you need to be more specific..... guys he is talking about the 350 tranny. it has the different wires and stuff like that he wants to know if it will fit in his 68 and if the wires will work with his harness.
#7 | |
backed by a Turbo 350 Tranny. Now granted, I didn't put it in, but it all seems to work, even the 94 A/C and Compressor works!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#8 | |
Oh well.
I gathered he wants to put the 94 engine in his 68 with the 350 TH. I believe the only major problem will be a special intake manifold to use a carb.
its all about the +6 inches
questions we need answered....
Whats in your truck now engine and tranny what tranny are you plannong on running? Do you want fuel injection, or are you happy with a carb? You looking for a lot of power, something peppy, or regular strength |
thank you wwotr whoever did it looks like they know what there doing and its ok i do the same thing
wrenchbenderret yes you are right i have the manifold to use i getting a 1640 Edelbrock to put on it longhorn man i dont have any thing in it all i have is the cab from a 68 GMC and im getting a long bed 68 with a front disc brake conversion kit from a long time ago the tranny is going to be 350 im going carb and ill go for ether lots of power or something peppy thank you for the help
You'll need a somewhat special intake. If memory serves, a 94 would still have the bolts on the center runners, but at a different angle. Look for an intake made for vortech heads. Costs a little more than an old school intake.
You'll need an electric fuel pump. Don't get a cheap one, cheap ones are generally crap. Look into the details, you'll probably need a regulater and have the pressure pretty low. A return line may be needed may not... again, plan out the system and look at the details. The engien will bold in like any other small block. If you use factory mounts and put them in the factory small block location, then other parts will fit better... headers for a 67 - 72 will drop in no problem, a short shaft TH350 and crossmember, it'll all fall into factory holes... even a stock 2 piece driveshaft. |
#13 |
WOW ok cool thanks i have a Weiand stealth summit intake will that work and the 350 is a 4 bolt main.
#14 |
Is the intake designed for tbi heads. A normal intake will work but you must machine the 4 center holes on a different angle. Pics r worth a thousand words
![]() Posted via Mobile Device
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
#15 | |
Curtis Posted via Mobile Device
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe Last edited by rollinhard; 09-22-2011 at 12:46 PM. |
#16 |
Ok I'll post pics tonight
#17 |
There are factory Q-jet intakes for both old and new centerbolts.
No way I would un-fuel inject it though. If you must use the TH350, just get a manual transmission PROM for the TBI. If you have a complete engine and trans from the 94 you will probably spend more to carb it and use the TH350 that to keep both electronic.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#18 |
so i should not do it if im going to put a carb on it
