Old 09-14-2011, 02:54 PM   #1
crispo-71
bagged rear pics!!!!
70 c10 shortstep side c notchd and bagged stock... i was looking on where 2 mount/relocate shocks, and where should i get the shocks. thanx
crispo-71 is offline   Reply With Quote
Old 09-14-2011, 03:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: bagged rear pics!!!!
Well, look in the vendor area under parts for the 67-72. Porter built has some nice stuff, there is another vendor that just posted a real nice set up too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-14-2011, 04:25 PM   #3
SCOTI
SCOTI's Avatar
If you use aftermarket relocators or modify your existing parts, you might be able to utilize OE replacement length shocks.
If you do lowering blocks w/bags & bolt-in style c-notch, you can use OE shocks w/the relocation brackets (lowering blocks allow for drop w/o affecting shock travel on truck arm suspensions)....
http://67-72chevytrucks.com/vboard/s...hock+relocator
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
