Old 09-14-2011, 08:26 PM   #1
blkcorvair
blkcorvair's Avatar
Rubber Squares for Mounting Bed to frame
Those Rubber Squares that everyone is selling to go between the Bed and the frame when you mount it... were they originally on these trucks new? I had none when I took mine off but all the bolts were also real snug. (Not loose) like I would imagine it would be if there was a 1/4" thick piece of rubber that had fallen out???
blkcorvair is offline   Reply With Quote
Old 09-14-2011, 08:32 PM   #2
Dark Knight
Dark Knight's Avatar
Re: Rubber Squares for Mounting Bed to frame
I put some on my truck before I got it painted. Jacked the bed WAY up. The body lines weren't even close.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 09-14-2011, 09:16 PM   #3
cdowns
cdowns's Avatar
i've always made my own the rubber i use is less than 1/8" thick and doesnt noticablly affect body line ailignment
my reason for using rubber was to prevent squeaks and rattles in the future
Old 09-14-2011, 09:28 PM   #4
john
member #16
john's Avatar
These trucks did not have pads when new.
john is offline   Reply With Quote
Old 09-14-2011, 09:33 PM   #5
Tim Christian
Tim Christian's Avatar
No they did not have them and these are old trucks they suppose to squeak and rattle! LOL !!
Tim Christian is offline   Reply With Quote
Old 09-14-2011, 09:50 PM   #6
gearys 5600
gearys 5600's Avatar
I did the same thing. I took them out after my body lines wouldnt line up.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 09-14-2011, 10:50 PM   #7
Dark Knight
Yep. It's metal on metal for me now. No squeaks. I probably can't hear them over the exhaust anyway if there are any. Or that roaring V8 under the hood. Or the stereo for that matter...
Old 09-14-2011, 11:51 PM   #8
crazy longhorn
Fabricate till you "puke"
Amen brother! If my old truck dont squeak & rattle.....it must be parked crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-15-2011, 05:36 AM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
I've never seen them on a truck I've taken apart. I added them to the stepside I'm putting together since the boards hit the frame rivets without them. I'm hoping that on a stepside the alignment of the bed to the cab isn't as noticeable.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-15-2011, 09:57 AM   #10
blkcorvair
blkcorvair's Avatar
I thought they were not original. Staying out for me. Thanks Guys. Ill use em to throw at people that come in th garage and bother me when I am so busy!
Old 09-15-2011, 11:10 AM   #11
68Mike
68Mike's Avatar
I had them on also but removed them as I figured without them my frame to bed would have a better ground...sounded good to me
Mike
Currents:
'74 Cheyenne Super C30 Camper Special 3+3
aka "Sucia30"
Past:
'79 C10 BIG 10 (Sold)
69 CST LWB - Always a "Work in progress" true work truck (stolen)
05 GSXR 750 it has a pretty paint job _wrecked
72 SWB full frame restoration -sold!
71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold!
C10 Club 2012 Brothers Show Video
http://youtu.be/pUeV2vP7Wpo
68Mike is offline   Reply With Quote
Old 09-15-2011, 02:21 PM   #12
phase_one
Yes the raise up the bed and alter the body lines. I decided not to use them.
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 09-15-2011, 03:13 PM   #13
hjewell2
hjewell2's Avatar
edited by staff: IV. Pure trolling, either to upset someone or simply for your personal
enjoyment, is strictly prohibited. If you're here to cause trouble, it will be a very short stay. Immediate BAN and you will be reported to your ISP
hjewell2 is offline   Reply With Quote
Old 09-15-2011, 03:15 PM   #14
cdowns
cdowns's Avatar
i've always built my old trucks with the ability of long distance travel on a very regular basis. to me squeaks and rattles when driving 800-900 miles in a day is neither cool nor acceptable. when a little bit of effort and thought building will avoid those annoying to me traits
Old 09-15-2011, 04:00 PM   #15
Tim Christian
Yes Sir, Built trucks all my life. Rubber pads under your bed is not going to stop squeaks and rattles Actually as the rubber deteriorates it leaves play between the frame and the cross sills yet causing squeaks and rattles or maybe you tighten your bed bolts a couple times a year. So I really still don't understand your point??? But to each his own.
Old 09-16-2011, 01:42 PM   #16
67chevemall
67chevemall's Avatar
Ya I thought they were OEM too. Took them out cause the body lines were wacked...
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
