Tire size help (BRAIN FART)
Need some help with tire size , Im taking the 10 inch wheels off the front and putting 8s in its place the tires on it now are 265/50/ 15 and for the life of me I cant remember the calculation I want to keep the same profile
Scott 82 step side aka " Bouncy " 73 GMC Long bed Vortec 5.7 |
Re: Tire size help (BRAIN FART)
The height is found by taking the middle number as a percentage of the first number. I explained it really bad. Basically with your number the height is 132.5, so 50% of 265.
If your new tire is 235 wide you would want a 235/55/15 which would give you a height of 129.5 (55% of 235).
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
thats what I was thinking but something told me nope
67-72 parts collector,…
![]() Join Date: Nov 2002
Try using this:
http://www.tacomaworld.com/forum/tirecalc.php
Take the tire width, times that by the aspect ratio as a decimal, times by 2, divide by 25.4 to switch mm to inches, then add the wheel size...
Here's what u have... 265 x .50 x 2 ÷ 25.4 + 15 = 25.43" Posted via Mobile Device |
Parts and more parts
Do you want to make it easy????
Use this calculator http://www.discounttiredirect.com/di...foTireMath.jsp
Frank |
