Looking for air filter for compressor
I have an 80 gal. 2 stage machine from Atlas that works like a dream. The problem I'm having is with water in the lines. Seems after the machine cycles a couple of times, it creates water in the lines due to the increase in temperature. I do alot of media blasting, da sanding and continues use that causes the machine to heat up the top of the tank. I also plan to tackle painting my project pretty soon and water in the lines will not do.
What are my best options to remove unwanted particulates and water for blasting and painting.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
Re: Looking for air filter for compressor
These work well and replacement filters are cheap. desiccant filters work well too.
http://www.tooltopia.com/motorguard-m60-2.aspx |
I am a Referee of life.
When you install a filter,put a drop leg with an automatic drain in before the filter.It will help keep the air dry and clean and make the filter last much longer.You could also use an air line sryer but I doubt you can afford to buy or run one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Dec 2009
What brand automatic drain do you guy's recommend?
Hand Crafted C-10
![]() Join Date: Aug 2006
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... Last edited by ETsC10; 05-04-2012 at 04:39 PM. |
