Old 09-15-2011, 12:33 AM   #1
wildbill8264
decoding vin on '67 GMC
I've been trying to decode the vin number on my '67 GMC short bed stepside. I'd really like some help with this. Every site I've tried online so far hasn't been any help because all the sites ask for 17 digit vin and my truck only has 15. I'd really like to know which engine/transmission and any other info about my truck that vin could provide. So any help with this would be great.
wildbill8264 is offline   Reply With Quote
Old 09-15-2011, 12:42 AM   #2
67chevy1series
67chevy1series's Avatar
Re: decoding vin on '67 GMC
we are going to need the numbers of the vin you can keep the last 5 or 6 if you want... but even then it tells about your truck.
67chevy1series is offline   Reply With Quote
Old 09-15-2011, 02:13 AM   #3
wildbill8264
the vin on my '67 GMC pickup cm1570cpc*****a
Old 09-15-2011, 04:12 AM   #4
matthones
matthones's Avatar
Check out the VIN decoder on here: GMC paul
C=2wd
M=V6 gas
1= 1/2 ton
oc=fender side
p=pontiac, mi (assembly plant)
c=1967
Matt
'68CUSTOM
matthones is offline   Reply With Quote
Old 09-15-2011, 06:20 AM   #5
Hey Wild Bill,welcome to the website. That's a neat little '67 Fenderside you have there.
That doesn't explain the 4th and 5th digit correctly. On Paul's decoder it's the same. His decoder also says the 6th digit is the plant and in his example it's the 9th digit. The 4th and 5th digits are supposed to be letters for the bed type and they are numbers. The 7th digit is supposed to be a letter for the model year and it's a number. I'm confused.
The VIN will tell you which motor configuration but not the size. For instance,your's is a V6 truck and it doesn't let you know which one. It doesn't tell transmission either. The model number tells more and the label on the dash tells all options. Unfortunately,it would be rare for you '67 GMC to have one. For the most part they just were never put in their place.
I can see it's been fixed up with some things changes. But,from what I see it didn't have the Custom or Super Custom options,which would have given bright work trim at the windows. So,your seat would have been a full vinyl bench and the grille/bumpers/hubcaps would be painted. Power steering is a rare option on those,which would be a ram-assist type.
Old 09-15-2011, 11:13 AM   #6
Tim Christian
Tim Christian's Avatar
Straight out of my 1967 GMC Truck Service Manual
C = Conv. Cab
M = V6 Gasoline
1 = 1/2 Ton
57 = Wheelbase
OC = Fenderside
Tim Christian is offline   Reply With Quote
Old 09-15-2011, 02:27 PM   #7
wildbill8264
Thamks everyone for your help in decoding this vin number.From what i've been able to find if my truck had the V-6 engine it would be a 305 V-6. Right now I've got a 305 V-8 in it. My Ol'truck is a work in progress, and it keeps me out of trouble
Old 09-15-2011, 04:03 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome Wild Bill from your neighbor in Lake County! Nice truck.
Mine's a work in progress too.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 09-15-2011, 05:49 PM   #9
MusicMan70
MusicMan70's Avatar
Welcome WB...in case you weren't aware it it's existence, here is some great GMC V-6 info...
http://www.6066gmcguy.org/
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-15-2011, 07:03 PM   #10
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
C = Conv. Cab
M = V6 Gasoline
1 = 1/2 Ton
57 = Wheelbase
OC = Fenderside
Yep, Its also in the 67 GMC owners manuals. For the 1st digit, if its a K, then its a 4x4 conventional cab. If its a P, its a forward control.
This truck could have had a 351 V6 as well. An interesting side note, the V6's holds about 7.5 gallons of coolant compared to 3 for the inline 6's!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-15-2011, 08:37 PM   #11
bruceman1968
bruceman1968's Avatar
WildBill, Welcome to the forum from another Florida boy.
I have looked for a good vin decoder for the 1967 GMC for a while all over the net and in books, and never found a good one. There's lot's of them for the 68-69 GMC and lots for the 70-71 GMC. But the 67 GMC does seem to be a different format. So after researching lot's of text I just made one that seems to work. Here is a pic using your vin. Sorry I have no photoshop or powerpoint skills. If you save the pic and blow it up you can read it better.
Nice lookin truck you got.
1967 GMC VIN DECODER
So you have a 2wd, v-6, 1/2 ton, shortbed, fenderside, built at Pontiac, in 1967, and gvw is less than 6000.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
