Old 09-15-2011, 09:58 AM   #1
Trucknut57
Trucknut57's Avatar
Question I need some header info / help
I currently have a set of block hugger headers on my 350 in the 57. The problem is they are not sitting correctly on the engine. The collectors are hitting the oil pan on pass. side and the motor mount on the drivers side. Which doesn't allow them to seal without using three sets of gaskets.
What are other using for headers? Brand, type (shorties, mid length, long tube)? I am still using the under cab brake mount with a hydroboost unit attached to it, so the headers still have to allow brake pedal travel.
Any suggestions would be great, because I can't seam to find a set that works.
Thanks,
Wess
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 09-17-2011, 03:10 PM   #2
Trucknut57
Trucknut57's Avatar
Re: I need some header info / help
Anybody ????
- dcozzi
Old 09-17-2011, 03:31 PM   #3
Coupeguy2001
Coupeguy2001's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Coupeguy2001 is offline   Reply With Quote
Old 09-17-2011, 10:25 PM   #4
Trucknut57
Trucknut57's Avatar
Whats that got to do with my question?
- dcozzi
Old 09-17-2011, 10:44 PM   #5
jocko
jocko's Avatar
Now THAT'S a good question! I don't see anything wrong with your post - but I also can't help answer your quesiton either.
If you've got to get new headers anyway, have you considered any of the re-done ram's horn lookalikes? They should leave plenty of room for pedal travel, etc..
Old 09-17-2011, 10:56 PM   #6
Rude Dude
Rude Dude's Avatar
Thanks,
Wess
First who made the down tubes the headers should not touch the block at all. I have seen some China made copies that were built wrong. My flanges on block are 3/8 thick and headers don't even come close to block. For the down tubes that go back I bought speedways and tilted them a little at the collector before I welded them up no interference whats so ever.
Rude Dude is offline   Reply With Quote
Old 09-18-2011, 12:11 AM   #7
parkwood
parkwood's Avatar
Thanks,
Wess
Wess these are coated Patriot Headers on a 350 chevy and you can get them from summit racing... they clear everything good.. you can get them coated or uncoated for you to paint.
What every header you buy get the one's for angle plugs, because they clear the spark plug boots much better..
Hope any of this helps..
Wayne
parkwood is offline   Reply With Quote
Old 09-18-2011, 03:27 PM   #8
Trucknut57
Trucknut57's Avatar
Jocko - I have checked those out and they are a bit pricey for wallet.
Rude Dude - I have no idea who made these headers but I agree they should never hit the block. Thats why they leak like crazy!
Parkwood - Beautiful engine!! Have you hooked up the rest of the exhaust? Any interference issues?
I have looked at so many different types and styles that I'm getting dizzy. Its so hard to tell from a catalog picture if they will fit. Any picks will help, this way I can see how they sit in relation to the frame and column.
Thanks,
Wess
- dcozzi
Old 09-18-2011, 06:40 PM   #9
parkwood
parkwood's Avatar
Thanks,
Wess
Don't let it get you down.... any good header company should make a header that will fit without hitting anything..
Yes the exhaust is complete and here is a few pictues of the set up.. no problems..
Old 09-18-2011, 06:47 PM   #10
parkwood
parkwood's Avatar
Here is another header we set up on a '56 chevy.. just showing you this so you're know it can be done with the full header too.. now this truck had rack steering and i'm not sure you've said what your's is... i could be showing you all this for nothing..
Old 09-18-2011, 07:39 PM   #11
solidaxel
solidaxel's Avatar
Have you considered using stock cast iron manifolds?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-18-2011, 09:13 PM   #12
Trucknut57
Trucknut57's Avatar
Parkwood - Thank you for the pictures. They helped out more than you know.
Solidaxle - I hade the cast iron stock ones before and I didn't like the way they restricted the engine.
I was looking at these: http://www.speedwaymotors.com/Small-...ders,3818.html. They look like the ones in the picture from parkwood.
Says they help improve mid to upper RPM power.
Thanks guys.
Wess
- dcozzi
