Old 09-15-2011, 01:20 PM   #1
coop34
Temperature Sender Adapter
I've seen many threads on the topic of a 1/2" temperature sender not fitting in the 3/8" whole in the block of a newer 5.7L, and I ended up going with a galvanized 90 degree step up adapter to solve the problem.
My question is, will I get an accurate reading if the end of the sender probe touches the inside metal of the adapter? I'm thinking that the metal would get hotter than the coolant which would give an incorrect reading. What do you guys think?
coop34 is offline   Reply With Quote
Old 09-15-2011, 07:22 PM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: Temperature Sender Adapter
there is a guy on here that turned the stock size sender down and cut the correct thread for a good price. ill contact him if you want?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 09-15-2011, 07:27 PM   #3
coop34
Was that EROC? If so, he he hasn't logged into the site in years.
Old 09-15-2011, 07:28 PM   #4
vasquezmrysvll
"the other guy"
nope, different guy. i dont want to give info till i see if its ok with him. you want me to contact him?
Old 09-15-2011, 07:36 PM   #5
coop34
Yeah sure. Thanks. What do you think about the way I have it set up currently? You think the probe touching the metal will cause an inaccurate reading?
Old 09-15-2011, 07:37 PM   #6
vasquezmrysvll
"the other guy"
i dont think the 90 adapter is a good idea. plus it kinda looks hoakie?
Old 09-15-2011, 07:44 PM   #7
coop34
Without a doubt it looks hokie!
Old 09-15-2011, 07:46 PM   #8
vasquezmrysvll
"the other guy"
i just dropped him a pm. ill contact you when he responds. -art
Old 09-15-2011, 11:01 PM   #9
JJanzen
JJanzen's Avatar
Sign me up for one as well. I had to install it on my intake and don't like it there. Would love to be able to move it down to the block.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 09-16-2011, 12:05 AM   #10
vasquezmrysvll
"the other guy"
as soon as i get response, ill pass the word.
Old 09-16-2011, 10:55 AM   #11
Lee H
Lee H's Avatar
I drilled and tapped a new hole. Only took about 25 minutes including manifold R&R. 1/2 NTP tap and 23/32 drill bit.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-16-2011, 12:07 PM   #12
dmack91
dmack91's Avatar
I tried either a 90 or a T fitting years ago on a friend's car and the gauge wouldn't read right. My guess was that the fitting creates a space where the coolant doesn't circulate through (just sits static) .
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 09-16-2011, 01:54 PM   #13
coop34
Thanks for the reply Demack. That's what I was suspecting.
Old 09-16-2011, 08:58 PM   #14
bollybib
bollybib's Avatar
I was thinking about doing that but after thinking about it awhile, and coming to the same conclusion as dmack, I decided to just screw the 1/2" sender into the intake manifold. It reads a bit low, but as long as I can see the coolant temp behavior I'm good with that.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 09-17-2011, 05:59 PM   #15
vasquezmrysvll
"the other guy"
pm member "brian mac" for details. makes this conversion SUPER easy
