Old 09-15-2011, 01:46 PM   #1
Ackattack
Ackattack's Avatar
fuel tank gas cap
In my 69 pickup, I recently got a gas cap for a 69 3/4 ton from LMC. When I take the cap off, you could hear air being sucked in or out. I figured they gave me the wrong gas cap.
So I got another one from another company while at the goodguys show. It has a blue vent thing in the middle (inside) of the cap. When I took it off, same thing.
What's up with this?
Ackattack is offline   Reply With Quote
Old 09-15-2011, 04:39 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: fuel tank gas cap
If you have the correct cap it should have a hole in the middle with that has a spring loaded plunger valve. This regulates the tank pressure which usually is around 3psi if I remember correctly.
The hole is about 3/16th (plus or minus) of an inch and if you insert a small object you can feel the spring loaded vent cap moving.
68gmsee is offline   Reply With Quote
Old 09-15-2011, 05:54 PM   #3
cdowns
cdowns's Avatar
you should b able to get the right cap at about any autoparts store
Old 09-15-2011, 06:01 PM   #4
nightmare
nightmare's Avatar
that's normal. if you unscrew the cap on a new car, it does the same thing. the newer cars also have a warning stating "Caution, contents may be under pressure"
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-15-2011, 11:29 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
you sure nightmare, cause I can hear my tank contract when i take mine off too LOL
John
1999 Toyota Tacoma 4x4
Old 09-15-2011, 11:32 PM   #6
snaus32
snaus32's Avatar
very strange mine started doing it too! changed the cap and still does it occasionally.
snaus32 is offline   Reply With Quote
Old 09-16-2011, 03:31 AM   #7
wwotr
wwotr's Avatar
For YEARS I had been tryting to locate a "CHROME",
Locking Gas Cap for my 72GMC.
Everyone listed one for UP TO a 71 (but not 72).
I bought probably 3 different types, and NONE of them fit.
Either the "Tangs" would be off or the "Body" of the Cap, was too big.
I finally gave up and went to Kragens and bought a Locking Gas Cap for my 72.
Iwhen the gut pulled it out of the Box, it was CHROME (w/Blue Ring) as you described.
I was happier than "White On Rice".
Mine had the EEC too.
Just thought I'd share.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 09-16-2011, 08:04 AM   #8
OJ1988
Just a car guy
OJ1988's Avatar
I have posted about this before, I bought 4 or 5 caps from various sources and never could find the right one.
http://67-72chevytrucks.com/vboard/s...d.php?t=366184
Swapped yo a vented blazer tank so it's not a concern for me now.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-16-2011, 08:28 AM   #9
Ackattack
Ackattack's Avatar
I looked at my first "new" gas cap last night and it has this set up in it. I poked something down in it to see if it was spring loaded. It kinda caught on something, and then you could feel the spring.
Oh well....maybe this is just the way they're supposed to be. And maybe we're just used to old gas caps that the seal is worn out, so it doesn't pressurized.
Old 09-16-2011, 09:07 AM   #10
OJ1988
Just a car guy
OJ1988's Avatar
The cap is the vent. It has to vent or these tanks will get a vacum in them.
1973 Vega Drag Car
1970 C20 tow rig
