HELP!!!! Truck won't start
So....I did a lil minor tune up on the truck....new spark plugs new wires new oil....was given a battery a guy in my car club wasnt using....went and got it tested and charged and they said it was good....today I plugged and attached everything back together....when I went and put the key in to crank it over....NOTHING....so now Im stuck....
Imma be honest and admit what lil I do know about what Im doing is what I have learned here and there....so any advice would be much appreciated.... THANKS GUYS!!!!
1964 Chevy Longbed Fleetside Valley Cruisers C.C. Sgt. of Arms |
Re: HELP!!!! Truck won't start
if when you turn the key and nothing come on, (radio, light) with no clicking sound, then your cables might not be hooked up correctly or not tight enough. if instead the started clicks then your battery is dead.
ANY POSSIBLE CHANCE....it could be the battery terminals? I replaced them too....
This may be a long shot but it happened to me a few months ago. In my case I had done nothing to the truck. I thought at first it was a dead battery but it was fully charged. What I eventually found was the a wire going into the connector going into the firewall above the distibutor had gotten frayed and broken. The wires go to the ignition switch and such. I just fixed the wires and it started right up. I could be that when you routed the new spark plug wires it may have pulled one of those wires lose. Good luck.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
first things first, do the light on the truck come on?
Slow build: THANKS! I'll have to look into that....
Budman56: Nope! Nothing comes on....no lights nothing....and when I just went out to the truck to try to wiggle this and wiggle that....see if anything would work....I noticed that when I disconnected and reconnected the battery cables....when the terminals would come in contact with the battery....I wouldn't get any sparks....maybe bad wires now?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
maybe dead battery? where is your other battery? try that.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
try jumping the truck with a charger/jump box.
I think you should start with the battery,then work your way up the connector etc etc. Electrical things are strange at times!
I put my bet on the battery! |
Clyde65: the other battery I know was dead....plus I was gonna replace that one anyways....but I'll take it to get charged....try that one....and if all else fails I'll try jumping it....
Is there a red wire that goes on the battery with the positive terminal ?? without this wire(should be red ) nothing will work ,it should cross from the drivers side near the radiator , go across the radiator support and end up by the battery...
![]() Join Date: Jan 2011
You can take that battery to most any parts store and they will test it for free.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#13 |
Make sure when they test it they put a load on it, or it won't test right.
Posted via Mobile Device |
#14 | |
This got me when I was a new owner. ![]() |
#15 |
Good luck man, I know it's frustrating.
#16 |
Man if it isn't one thing its another....got the truck to crank over but now i think my alternator is going out and i got a leak in my oil pressure line!!!!!!!!!!!!
#17 |
welcome to old trucks my friend.
#18 |
First off I would like to thank all of you that put in your input to help me with the lil problem I had....but I am PROUD to say SHE'S ALIVE!!!!
#19 |
We need details.
What was wrong? How did you fix it?
#20 | |
after hooking that up to the battery....when i would try to crank it over it would go but it sounded like it was slowly dying....after thinking it was my battery....i tested it....it was fine....tested the alternator....fine....my neighbor helped me out and finding the electrical problem....the owner before the owner i bought it from....hooked up another ignition switch that did not belong to the truck....well the way they hooked it up was by tying ground, acc, and the ign wires together on the ign the sol. wire on the ground and the battery to the battery....IT WAS A NIGHTMARE!!!! Thank god i had a the proper ignition switch....but it was a big nightmare trying to find which wire was which....finally got it together....and now....starts right up! ![]()
#21 |
Resistance is Futile
Congrats on getting it running. My experience tells me you may have a few more rats nests hiding in there!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#22 |
Thanks protrash64! A friend told me to just replace the whole thing so thing thats the route imma go with....
