Old 09-15-2011, 06:06 PM   #1
bakerboys
bakerboys's Avatar
do driveshaft angle cause roar noise
6 inch lifted k20 has roar only when on gas do driveshaft angles cause this
bakerboys is offline   Reply With Quote
Old 09-15-2011, 07:56 PM   #2
LONGHAIR
Re: do driveshaft angle cause roar noise
In general, no. Bad angles can cause vibrations but not usually noises.
The fact that it only does it under throttle would lead me to worn ring and pinion gears. If it were a bearing, the sound would be pretty much constant.
Pop it open and have a look, it could use a change of lube anyway. That is one of the most neglected maintenence items on nearly any vehicle.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-15-2011, 08:02 PM   #3
bakerboys
bakerboys's Avatar
Just changed both diff gear oil and saw no wear
Old 09-15-2011, 09:48 PM   #4
The rears are precision and rigid mounted. The only noises caused by too steep of a driveshaft angle would be in the u-joints. If it's causing a noise in your rear then it's a bad pinion bearing or pinion causing enough slop from the added stress of a steep angle to put it off center.
Old 09-15-2011, 09:52 PM   #5
bakerboys
bakerboys's Avatar
Guess I better get it checked out. Thanks a lot
Old 09-16-2011, 08:19 PM   #6
bigbadchev72
People know me
bigbadchev72's Avatar
What does your angle look like? You may have some axle wrap as well and causing your angles to get way out of whack when on the gas. I would also check out your u-joints they are most likely the problem and need changed
Edit: did you just lift it and it started making noise? are your front hubs locked in? I had a bad front driveline in my old 84 shortbox, it was worn out in the slip portion and made some knarly noises
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-16-2011, 08:33 PM   #7
bakerboys
bakerboys's Avatar
No I bought it already lifted I did have to put a universal joint in front driver side axle and I put manual locking hubs the noise sounds like it is coming from under my seat the th400 trans. Had water in fluid looked like pepto bismol so I put in a trans cooler and bypassed radiator then completly flushed trans. It almost sounds like it is coming from trans
Old 09-16-2011, 08:41 PM   #8
bigbadchev72
People know me
Try pulling the front driveline and see if it goes away. What t-case are you running?
Old 09-16-2011, 09:54 PM   #9
bakerboys
bakerboys's Avatar
It's not the 205. I think it is 207 I don't know I am a newbie it is aluminum
Old 09-16-2011, 09:55 PM   #10
bakerboys
bakerboys's Avatar
My front drive shaft does not turn until I engage 4wd. If I remember right
Old 09-16-2011, 09:56 PM   #11
bakerboys
bakerboys's Avatar
I need to check out the universal joints I guess
Old 09-16-2011, 10:01 PM   #12
bigbadchev72
People know me
it is a 208 then. Definately check the u-joints.
Old 09-16-2011, 10:03 PM   #13
bakerboys
bakerboys's Avatar
Are 208 bad
Old 09-16-2011, 10:18 PM   #14
I had to build a 2"longer rear driveshaft when I lifted a '72 6". Should be the same.Maybe yours needs to be longer causing the slip yoke to not slide in the transfer case far enough.
Old 09-19-2011, 06:38 PM   #15
liftlawssuck
liftlawssuck's Avatar
My transmission was hitting the side of the hole in the dog house only when I was on the throttle making a roar kind of gear whine. Opened the hole and it went away.
liftlawssuck is offline   Reply With Quote
Old 09-19-2011, 07:35 PM   #16
bakerboys
bakerboys's Avatar
Could you explain what hole
Old 09-20-2011, 08:20 AM   #17
Shifter hole? Just a guess.
Old 09-20-2011, 06:24 PM   #18
liftlawssuck
Yes the shifter hole in the dog house. I have 2. 1 for the tranny and 1 for the transfer case. When I swapped mine over to a standard years back I made a hole just clear the top of the transmission. Looked great, nice and neat. But when I finished the whole thing and drove it, it whined like no tomorrow when on the throttle. I don't mean really hard on the throttle just normal driving. The torque of the motor was twisting the tranny and hitting the doghouse. So you had metal to metal contact that acted like an amplifier. It had a lot of gear whine and sounded like right under your seat like yours. It's like holding a screwdriver to the valve cover to listen. It just amplifies it. So I pulled the carpet back up and trimmed the hole open more and noise was gone. I have a 79 short bed with 6 inch lift and have no drive train noise from angles. That's what it sounds like to me but... Hope this helps.
Old 09-20-2011, 06:56 PM   #19
bakerboys
bakerboys's Avatar
Mine is a auto with shifted on column
Old 09-21-2011, 07:58 PM   #20
liftlawssuck
Right but what about the 4 wheel drive shifter or the torque arm? If it is hitting the doghouse it will make that noise. Or anything else that it touching the tranny, transfer case and touching the cab will transfer the noise and amplify it. I don't know but worth checking.
Old 10-08-2011, 12:18 AM   #21
bakerboys
bakerboys's Avatar
it is just crazy how loud it is when i press the gas pedal at any speed going down the road then as soon as i let off gas it stops I dont know what to do
Old 01-10-2013, 09:34 PM   #22
dieseltech
not to dig up an old thread but i have this exact same issue and was wondering what you found with your truck?
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
Old 01-12-2013, 12:40 AM   #23
SunSoaked
SunSoaked's Avatar
Torque converter. Had the same issue in a car application. The torrington bearing inside was kaput! Only did it when on the throttle. I cut the converter apart and it was obvious-the bearing surface was chewed up and blue from the heat of the failed bearing.
SunSoaked is offline   Reply With Quote
