Front track width.
Does anyone know what the front track width is on a 64 short box??
I"m sliding an 80 scottsdale under it... is it wider?? it's cheap and power steering and disk brakes.. |
Re: Front track width.
Im not 100% sure if there the same but I slid a '79 cross member into my '66 and only had to drill out two holes. Bolted up to the frame with no problems.
I am a Referee of life.
The track width is about 3/4 in wider.You can got to a later 71-72 rear end and get things evened up or do it with wheel offset.This width measurement is true wether using a later model crossmember or aftermarket,though I "believe" there are a couple of companies offering a narrower track width disc kit.Only people with a good understanding of these trucks will notice.And you since it will be one of those little things you know and it will stick out like a sore thumb to "you".
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
A day late and $1 short...
The track width is 3/4" wider on each side. This is in the control arms, not the crossmember. CCP's modular drop spindle corrects this, but I'm not sure if it corrects the entire 3/4". I swapped the entire crossmember, but if I had it to do over I would have left my crossmember in place and just swapped the control arms and steering components. There are tabs for brake lines on the early crossmembers and I think it would have been cleaner if I had them to use with factory style lines. Just my $.02.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
