Just about had enough
This POS of a truck I own is really pissing me off! Today is the first cool day (55 to 60 degrees tops) I have tried starting the truck. I ended up draining the flippin battery trying to start it. The f'in carb does not have a functional choke, so it stays open all the time. I can never tell how many times I need to pump the gas to ensure the engine can start. And when the battery does get low, the f'in starter wants to **** all over the flywheel.
I like this truck, I really do. But why do I end up with **** like this? The truck is dead until I can get the battery to AZ and get it recharged. I really wish I knew some people that were knowledgeable about this stuff that were close by that would be willing to help me fix things. All I have to rely on is a Haynes book and these forums. ![]() ![]() ![]()
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
Re: Just about had enough
manually engage the choke. starter fluid can help
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Ok a properly tuned motor should only require a choke in real cold weather. Sounds like it has some issues, but if it runs fine and doesn't knock, smoke, or leak it's all minor stuff. Most people try to pump the gas and crank at the same time, this usually is wrong. One or two pumps, then hit the key, if it doesn't fire up, repeat. If you are having to crank on it till the battery goes dead, you've got some tuning issues that need attention. I know it can be frustrating, but it can be fixed.
Hang in there!
Perhaps you could find some other truck enthusiast in your area that could help you out. If all else fails post something on Craigslist; JUST BE SURE TO CHECK THE PERSON OUT BEFORE YOU GIVE THEM YOUR HOME ADDRESS. There's just too many freak out there. I spent half a day one day last week rebuilding my carb and getting the choke to work. Fix it correctly once and put this issue behind you.
1984 C20, 454, 4 speed named "Gold Member" |
#5 | |
I'm getting a manual choke cable tomorrow. Can I get away with the fast idle cam unhooked until I get linkage kit or new carb?
Spend $12 on a manual choke kit -easy install and solves all choke problems.
I find that even in AZ on hot days a choke is needed for cold start up, then you can open the choke immediately. |
#7 | |
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
Don't even need the choke. I've had MANY vehicles that never had the choke hooked up and never had one not start. I live in the northeast, so it gets plenty cold, like below zero cold. Two maybe three pumps and it's running. Now I'll say this, it will start, but won't stay running until it is warmed up. I'd say you have other issues.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
#9 | |
78K & 79C Jimmys
wait for it to catch...and spit..maybe a stall and my foots the choke till it's warm.....@-40C don't pump.....pour gas in the carb.you will know its in
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
in that warm of weather you don't even need a choke! i have had many carbed vehicles in idaho and they started without a choke in temps down to 30's. sounds like if its missfirreing often at cruise that your timing is off. does it crank funny or smooth?
when it tries to fire does it kinda skip? can you smell fuel while cranking? really sounds like your issue is timing and a little carb tuning i haven't noticed where are you from? |
Invest in a battery charger and it sounds like after timing is reset and you fine tune everytrhing you should be gold.
What's your location? I bet there are some members not too far that are willing to help. If you're anywhere close to me, I'd me more than willing to assist. It sounds like a little more tweaking to get it right.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#13 |
Exactly where I was, Ottawa. I remember a couple times where it was -40, and two pumps maybe three, my 78 Malibu with a 200k 400 would start right up. It wouldn't idle, but would start. Once you get it running, if it stalls it will be easier to start.
I would try one pump when the truck has been sitting or if it's cold. Crank for a couple seconds, if it doesn't start, try to pumps. In less your accelerator pump isn't working, you should get something.... Like the others mentioned, get at least a trickle charger, check the timing and make sure everything is up to snuff.
#14 |
My big block will start without using the choke, but will require pumping some gas into the carb. By closing the choke first, I do not have to give it any gas at all, unless the truck has been sitting for a few days without running.
#15 |
Remember, they don't need to be truck people. None of the riddles you are trying to solve are unique to trucks. Go to a car show or swap meet in the area. That is where you will find them.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
#16 |
I appreciate everyone's support. I have updated my location to reflect where I live.
I plan to check the timing today once the battery gets recharged. Plus swap the alt for one that isn't dumping AC into the battery, and install a choke cable. Thanks again.
#17 |
**** this piece of ****! I get the battery recharged, the alternator replaced (again) and all I get is 1 click from the starter solenoid. It won't even attempt to crank at this point. I am really ****ing pissed off. All I have been doing for the last 2 months is replacing ****ing starters. Now the truck is on the street and it will be a ***** to replace like the last 4 or 5 times.
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ![]() ![]() ![]() ![]() ![]() ![]()
#18 |
How do the battery cables look? Check your grounds to the body and frame.
#19 | |
#20 |
You don't want to hear this, but what you have is likely a simple problem.
Is your battery holding a charge? Try jump starting the battery you have or put it on a small battery charger if you have one. Once you have it started, take it back to AZ and ask them to do a free check on the charging system. If you still have trouble getting the engine to crank over, have the starter checked. But first, take off the battery cables, make sure the battery posts and cable ends are clean and tight on both ends of the cable. Also, check the connections at the starter, but do NOT over tighten the connections at the starter or solenoid. I have installed parts before finger tight and forgotten to go back and use a wrench to finish the job - got distracted or whatever. Once you solve the no start electrical problem the manual choke will fix all choke issues. If none of this works you can check to see if you have current to the solenoid when the ignition key is turned to the start position. |
#21 |
God is good!
Don't give up, we've all been through similar issues with our vehicles at one time or another. Have you ever had the carb rebuilt? What kind of carburetor is it? Plug wires changed? Distributor cap and rotor changed? These are all simple items to look at and change. Your starter may also need to be shimmed. Does it sound like it is making good contact with the flywheel? How do the flywheel teeth look?
Approach it in a civilized manner--look at these things as challenges to make you learn about your truck. Remember, its just a machine. There's a wealth of information all over the internet, too. I wish this information was around when I started working on my vehicles years ago.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
#22 |
Try jumping the solenoid as said earlier. Either with a screwdriver, small pry bar or remote starter. It wont shock you. If it cranks and even fires, then it's a bad solenoid. Jump the battery terminal on the solenoid to the "start" terminal.
#23 | |
Start fresh, plugs, dist cap, rotor, wires, make sure the starter is shimmed right, adjust the timing until the motor fires quickly, and then see where you're at. If the carb needs work find someone that can do it for you. |
#24 | |
#25 | |
