Old 09-16-2011, 09:56 AM   #1
summerj
NEED ADVICE/ Recommendations on...Rear END ?
Hello All- Just purchased a '65 fleetside last weekend. I dont know much about the what appears to be the stock rear end in it. (The pumpkin is round like some of the other Eatons I have seen on here.
I have the opportunity to purchase a 1989 Chevy Iroc Posi rear end. ($100) Assuming its the same width, would this be an upgrade. I realize I may have to move the spring pearches but thats not a big deal to me. AM I Under ESTIMATING THis JOB? Yesterday I notice a small puddle of thick gear oil on the drive way from the current rear end.
Is this Eaton Rear End Worth Keeping? Or will the IROC Posi Be an upgrade?I will also be adding disk brakes to the front so I could find some 5 bolt rotors to match the IROC Posi Rear.
truck has a mid 70's 350 with power glide. I am looking to swap it for a 30 spline 700R4.
I am setting this truck up as a daily driver. It needs to have good brake on it as I will also be pulling a trailer.
summerj is offline   Reply With Quote
Old 09-16-2011, 01:18 PM   #2
summerj
Re: NEED ADVICE/ Recommendations on...Rear END ?
Also ....Forgot to ask What gear ratio in rear end would be best for 700R4 Daily driver?
What is everyone running?
Old 09-16-2011, 01:27 PM   #3
Indian113
Indian113's Avatar
I'm not a expert but I wouldn't go any higher than 3:42,I have 3:73's in my 64 and it is great with the Od trans. A lot can change with the height of your tire also
Indian113 is offline   Reply With Quote
Old 09-16-2011, 06:03 PM   #4
Scot_Douglas
Scot_Douglas's Avatar
FWIW, the IROC posi will be a 10 bolt with an eaton gov-lock. While I've put many miles on on one, it wasn't in a hotrod; most people online have nicknamed them the "gov-bomb".
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-16-2011, 06:48 PM   #5
Greshampiglet
I'm not sure on the fit of the IROC rear end I put a 3.54 posi in my 64 GMC (it already had leaf-springs) I have the 700R4 and a 350 crate motor with an intake and 4bbl carb I'm getting 18 to 20 mpg on the freeway, as long as I keep my foot out of the pedal
GreshamP1GLET
Greshampiglet is offline   Reply With Quote
Old 09-17-2011, 12:29 AM   #6
Captainfab
60-66 Nut
I wouldn't bother with that '89 IROC rear end. They are a weak rear end, plus they have the 5 x 4.75 wheel bolt pattern. Trucks have the 5x5 wheel bolt pattern. If you do have the Eaton HO52 under your truck, should we assume your truck is a C20? If you are wanting to convert your truck to a C10, then I would suggest looking for a '64-'87 C10 rear end. As for gears behind a 700R4, I wouldn't go any taller than 3.73's since you want to pull a trailer. Of course this all depends on how tall of a tire you plan on running. That affects your overall gear ratio.
Old 09-17-2011, 12:26 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
In with captain on this one. The 3rd gen camaro guys try to get out of that 10 bolt rear end when they start making decent power, it really wouldn't be an upgrade. The truck 12 bolt rear is available, strong and has enough aftermarket support should you want to change gear sets. The car 12 bolt is supposedly a little stronger, but since those are much harder to find these days, its probably not worth what you'd pay.
Since you mentioned going disk in the front, just get the truck 12 bolt rear...this way your rear will be 5x5, and your front will become 5x5 (assuming you just throw the newer style gear up front)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-17-2011, 04:19 PM   #8
summerj
OK Thanks guys for the input. I will pass on the Iroc rear..
Are the gears, seals, wheel cylinders brake shoes etc. hard to come by for this stock 65 1/2 ton rear end that I have? Maybe I will just add the brackets to it and get the monte carlo or Caprice rear disks that many on here have.
I need good stopping power since I will be hauling a 2500LB catering trailer. (It too has electric brakes) . I Need it to be good daily driver.
Old 09-18-2011, 02:39 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
i didn't see anything about which gears are in your current rear. If its a low set of gears, it wouldn't even be worth upgrading the brakes to find out it doesn't have enough dig to get the trailer moving.
I'll be converting my rear to disc as well, which is REALLY nice when it comes to slowing down a truck AND trailer.
Old 09-18-2011, 09:52 AM   #10
samuellg1977
samuellg1977's Avatar
Greshampiglet, I have exact same set-up... And mine is also in the low 20's freeway just above idling at 75-85MPH. When the secondaries open up, she'll suck dents in the gas tank, though!!
Sam
samuellg1977 is offline   Reply With Quote
Old 09-19-2011, 12:08 AM   #11
Captainfab
60-66 Nut
The truck 12 bolts were used from '63-'82 in the C10's and '63-'80 in the K10's. Parts for these are readily available at either your local auto parts store, or from some of the differential parts suppliers.
For increased braking you can certainly convert to rear discs (I have the brackets to do so) in addition to front discs, or you can upgrade to the wider 2-1//2" shoes and drums which started in about '76-'77. You will need to change the backing plates to do so.
