drag it like you stole it
rear bag mount help.. anybody
the truck has stock trailing arm suspension, and i had the bags mounted over the axle, but the lift was pathetic. so i moved the bags onto the trailing arms. i mounted them off to the side on some plate. i have gussets on the mounts as well. but when i put air in the bags, and i push pown on the bed the trailing arm kind of twists a bit in the middle. i think it may actually be twisting in the front of the arm where the bushing is. but i can only see the middle where the mounts are. is this going to fail sooner or later, or will it be ok? i cant think of any other way to reinforce it. the bed as a 15gal fuel cell, air tank and compressor and two bottles of nitrogen. so that is the weight in the rear. please help. i really dont want to redo them, but i will if it will be unsafe.
negative camber //LA\\ |
Lotik, I welded my trailing arms up. I did 2" sections of weld every 6" or so along the top & bottom + welded the front & rear. To increase the strength, just plate the tops/bottoms.
Any pics? Of both Scoti And Lotik's setups?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
thats the problem with adjustable suspensions and 2 links. you could try boxing them for strenght, but idealy a 4 link is best.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
I Love This Stuff!
Why did you choose that location for your bags over the factory springs location?
My Rides 1967 C10 In Pieces for now ![]() 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
hey lotik why dont you move your mounts just a little bit more forward to where the bag is right over the trailing arm. thats what im gonna do when i get to that stage. ive been studying it for a while and that seems to be the best place.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
oh and if you dont mind take some pictures when you get done, cause its in my head but i would like to see some pictures too
i think i am going to reinforce the trailing arms. i really like the lift i am getting now.
