Old 09-16-2011, 03:28 PM   #1
imholte
imholte's Avatar
New power steering is weak, they say normal
My pickup wandered very badly on the road so I took it to the local alingment shop and they told me I needed new power steering pump and box as well as tie rod ends.
Well I get the truck back yesterday and the steering is hard to turn. Before I could do it with a finger, now at low speeds and stopped it takes both hands to wrench the wheel around. I took it back and they told me that is how old trucks are and since I have a smaller than stock steering wheel on it I wont have as much leverage. I dont know what to do since I spent lots of money and now it is hard to turn but they say its normal?
Any ideas?
72' Custom10 4wd 350: Daily Driver
imholte is offline   Reply With Quote
Old 09-16-2011, 04:10 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: New power steering is weak, they say normal
Get another opinion. I have a small wheel and I can use one finger anytime. It should not take 2 hands with Power Stearing
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-16-2011, 04:12 PM   #3
bigguy69
dazed and confused
bigguy69's Avatar
I agree. Sounds like something is not right.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-16-2011, 04:46 PM   #4
71 super
71 super's Avatar
It should be very easy to turn, one or two fingers is all it should take. All of the trucks that I have with power steering are very easy to turn including the 4x4. I would question their work- it sounds as though they replaced with a manual box.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-16-2011, 05:42 PM   #5
landsurvey1
landsurvey1's Avatar
Maybe it is a bad power steering pump? The same thing happend to me. My steering worked fine and then I upgraded to a chrome pulley system with new power steering pump, water pump and so on. Hooked everything up, jumped in it and the steering was not even close to being normal. Turns out it was a bad pump. I think a way to check it is by starting the truck, and then take the cap off the pump and see if the fluid is circulating? If it isn't, it may be a bad pump. Just my .02
landsurvey1 is offline   Reply With Quote
Old 09-16-2011, 06:13 PM   #6
imholte
imholte's Avatar
They are going to order a new pump and see what that does and then go from there. But I have to wait till monday for that.
I figured that I would just take it in and have it done by a professional so there is no hassle. I could have done it myself and saved alot in labor but i figured they would do it right and get it done quick. Hope the new pump helps.
Old 09-16-2011, 07:17 PM   #7
cdowns
cdowns's Avatar
if you have very big heavy oversized tires effort increases
Old 09-16-2011, 07:51 PM   #8
bigbadchev72
People know me
bigbadchev72's Avatar
I am running the stock setup on all 3 of my rigs taht are running 35-38" tires and unless I have them wedged in some rocks it is very easy to turn.
I am betting bad pump or they still have air in the lines. Look in the pump and see if the fluid has bubbles in it or it is frothy. Put the front end on jack stands and turn the wheel back and forth for a while, should get most of the air out.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-16-2011, 09:10 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
there's a couple of other things that affect the steering. On the top of the gearbox there is an adjustment screw that can be tightened enough to cause binding in the steering. If there is too much tension on the screw then the lock nut can be loosened and the screw can be backed out a turn or so to take the binding out. It is there to compensate for wear in the gearbox.
On the back of the pump under the pressure hose fitting there is a relief valve that may have a weak spring that is allowing the pump to bypass and not build enough pressure to operate the gearbox. Since they changed both of your units then either one may be faulty.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
