Old 09-16-2011, 04:15 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Trans Cooler Line Fitting Size
Anyone know off hand what the thread size for the trans cooler lines going into the radiator is? Is it a fine thread or pipe thread?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-16-2011, 04:33 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Trans Cooler Line Fitting Size
I believe it is 3/8 flare. I know it's flare. You can get the pre made lines a any auto parts store, in the brake line area.
Dunenutt is offline   Reply With Quote
Old 09-16-2011, 05:05 PM   #3
john
member #16
john's Avatar
5/16" inverted flare nut.
john is offline   Reply With Quote
Old 09-18-2011, 11:39 AM   #4
71meangreenc10
Where could I find a tap and die to clean one up (also need to fix the radiator threads)???
Smitty
71 C30 Wrecker
Old 09-18-2011, 06:24 PM   #5
71meangreenc10
TTT
Smitty
71 C30 Wrecker
Old 09-19-2011, 12:14 AM   #6
rpmgroup
I have had to get a couple of 5/16 inverted flare nuts or plugs from the local auto parts store. used my die grinder with a cut off disc to cut a few reliefs across the threads at a slight angle (so it looks like a tap) and threaded it into the holes. this worked to clean up the threads that would not let my lines start.
rpmgroup is offline   Reply With Quote
