Introduction + VIN code
Greetings, all you GM truck gurus. I've been reading the forum for years, but wasn't a member until today. Great, great, great website.
So. I know my 71 Chevy K(C)-10 is a little different than when it left the Fremont plant (about six miles from here,) but I didn't know it was *this* different. According to the vin decoder, (as far as I can tell anyway,) it started out as a fleetside 2WD - is now a 4WD stepper. I'm curious about a couple things: 1) Paint code 534, white/med olive and black vinyl trim. Anyone have a photo of that scheme? Love to see it. 2) It was built with heavy leaf springs at the back as an option. I've never seen a 2WD SWB with leafs. Can't imagine why anyone would ever want to do that - and pay extra for the privilege? I'd like to put it back to 2WD, but if I was to do that, I guess the best move would be to buy a banged up SWB with coils all around and then transfer my everything onto that frame. Of course, I'd like to do lot of things... like buy a private island or take Mila Kunis to um... a movie. Maybe someday. Maybe not. Anyway, it's a sweet truck. 330 hp crate 350, turbo 350, ps, pb. It'll pass anything on the road except a gas station. Only bad thing is the ride. It's stiff as a donkey cart. The wife calls it the "pee truck," because that's what you have to do as soon as you've gone a mile. Oh well. I have some other questions about wheels that I'll put in a different thread. Paul Domeier San Jose, CA |
Re: Introduction + VIN code
Leafs all around is the way all 4x4's were.
127" wheel base is a long bed too. Has your frame been shortened? Is it even the original frame?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Petroleum User
Either the frame was cut, or the cab was swapped.
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
its all about the +6 inches
ce141z607519
C 2 wheel drive e v8 1 1/2 ton 4 cab with bed 1 1971 z freemont cali plant 607519 build number. Some plants used 500001 and other plants used 800001 as the first truck off the second assembly line at there plant. |
Pretty sure the frame isn't cut. Must be a different frame. Just gets more intrestinger and interestinger.
If you look on the top of the drivers side framerail under the hood just back from the steering gear box, there should be a partial VIN stamped there. With any luck, someone will post a photo I took 9 years ago or so and posted pointing out where it is. (I lost most of my truck pics in a computer meltdown) See if that matches the last half of your VIN.
![]() Join Date: Feb 2001
Hey domeier ...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Thats a good looking truck!
I should say lots of pictures
Thanks and hello back to all. I love this old truck. Had to do some economic downsizing earlier this year, which meant I had to choose between the truck and my '98 Z28. It was a hard call, but the truck won. The truck has a new engine and trans, and it's Godawful easier to work on than the Camaro was. Someday when I'm rich again, I'll buy another Camaro - and I'll pay some fool to work on it for me.
Here's the vin off the frame: Looks like 07164328... which ain't not at all the same number on the cab, so that explains some of the mystery. I'll take some pictures and put them up after I give her a good bath. Thanks again for the nice comments. Paul |
Are there shims under some of the body mounts? I wonder if that's a 73+ frame.
#12 | |
Paul |
#13 |
some more pichers...
#14 |
You may want to take that air filter off and throw it away.
I'll let you prove it to yourself as to why. Go out and pull the filter off. Now stick your noce in the center of the filter on the inside. Do you smell that raw fuel? Now, with the filter still removed, grab the throttlw and pump it once or twice... like you are starting it in the morning when the morot is cold. Did you see the fuel spray, or even splash upwards? All it takes is the smallest of backfires.... even just a hickup through the carb, and it'll ignite and go up in flames. On top of that, there is no flame arestor (most all aftermarket filters fail in this department). So you have a fuel soaked thin sponge, and a backfire, and nothing to stop the flames except maybe your HOOD. I heard these warnings, I ignored them, and ended up with the burned paint of shame on the hood. |
#15 | |
Here's what it looks like today. Maybe one of these days I'll get around to finishing the air-con install. Paul |
#16 |
awesome!
