At the body shop.
Brake Pedal
My brothers 01 suburban.
Replaced calipers pads rotors and all flex brake lines. Bled and bled And it still has a crap pedal. Is the master cylinder the culprit? thought's , opinions?
" That didnt make it any newer " " Dont antique the equipment " |
~Rest In Peace~
Re: Brake Pedal
i would replace it anyway with it being 10yrs old ,do you see any leaks around the back of the m/c by the booster ? does it have rear drums or disc ? may have to adjust the shoes if it had drums .
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
At the body shop.
Re: Brake Pedal
All disc. Its all dry around the rear of m/c
Active Member
![]() Join Date: Jul 2007
Re: Brake Pedal
ABS... Probably need to have a shop that has special equipment bleed them. They can activate the ABS and do a better job.
I had hell on my Tahoe and in retrospect, that's what I should have done. For starters, I had two new defective master cylinders. Then it took a lot of pumping by my wife who was tired of assisting but I finally got them working okay. Should have just taken it in. I'm stubborn that way, though. |
![]() Join Date: Sep 2005
Re: Brake Pedal
Unbolt the mc and slide id forward like an inch and see if the back is wet, but it cab be dry and still be bad if its an internal leak
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
