Old 09-17-2011, 06:48 PM   #1
truckdude239
truckdude239's Avatar
radiator doesn;t fit?
Went to put my old radiator in my new core support and it doesn;t fit not even teh new 4 core rubbers i got they are to big. what do i need to do i dont know what size radiator i need now i guess ing i got the wrong core support
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-17-2011, 08:37 PM   #2
mikey531
mikey531's Avatar
Re: radiator doesn;t fit?
I just drilled them out and moved them to where they did fit.
mikey531 is offline   Reply With Quote
Old 09-17-2011, 08:42 PM   #3
truckdude239
well that would be great but he whole mount is to small
David fuller
2000 Tahoe 5.3l 378
Old 09-17-2011, 08:45 PM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
I went through the same issue. There are different (longer) brackets for the four core radiator. You will probably need to change the top ones too. I can't remember were I bought mine, may have been Brothers. The mount on the lower passenger side of the core support will have to be moved over more to the left (passenger side fender). I had to cut into the core suppor so the bracket would fit in that location.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-17-2011, 09:33 PM   #5
truckdude239
i got teh top ones for the 4 core just need to figure out the bottom
David fuller
2000 Tahoe 5.3l 378
Old 09-17-2011, 09:59 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
I think this is what you are looking for. Is says "These are only available as the heavy duty style." Which I would think means a 4 Core Rad.
http://www.brotherstrucks.com/prodin...number=RRL0072
Old 09-17-2011, 10:08 PM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
there are threads i did about the same thing
http://67-72chevytrucks.com/vboard/s...d.php?t=241060
Old 09-18-2011, 08:51 AM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
X2 the mount is bigger on the bottom as it is on the top for the four cores, and as said one will have to be moved out some but the core support has the place made into it already for it.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-18-2011, 09:03 AM   #9
truckdude239
do the news on just botl in our they have to be weld?
David fuller
2000 Tahoe 5.3l 378
Old 09-18-2011, 09:17 AM   #10
Hubscrub
Cruzin
Hubscrub's Avatar
i think i have done both i welded (on my 71) were the hole is i think factory had a pop rivet? On my wife's i tried running a small bolt it was a pita i do remember not sure what i ended up with (went out to look can't tell with everything together) that best to spot weld in place for me. I did all mine while in the truck so junk in the way.
Proverbs 3:5,6
Old 09-18-2011, 09:19 AM   #11
chisler
chisler's Avatar
You do not have to weld...... being the 4 core style you will have to take a cresent wrench and bend the lip of the radiator support down a bit...then it will fit.....better to bolt it in...I did the 3 core to a 4 core in my k10....good upgrade!!!....you have the 4 core rubbers but you will need the support also
chisler is offline   Reply With Quote
Old 09-18-2011, 09:37 AM   #12
truckdude239
Yup got.to buy the lower supports if i had known id pulles then off the old support
David fuller
2000 Tahoe 5.3l 378
Old 09-18-2011, 10:05 AM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The swap is simple.It didn't take much longer than just swapping radiators.I used 4 core mounts and rad.I think I paid $180 for the rad at O'Riellys.I bolted in the lowers with small stovebolts.It was a bit tight to get to but I managed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-18-2011, 10:16 AM   #14
truckdude239
i have the rad just wish i had stole the mounts off the old core support before i sent it to the scaper, going to check with classic muscle(modern chevy) Tuesday and see if they have them and the gas tank gasket
David fuller
2000 Tahoe 5.3l 378
Old 09-18-2011, 01:11 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
They are available at almost any aftermarket store. I ordered some from Wes (Classic Heartbeat) for a 4 core... and I believe they were original GM parts.
I welded the new ones in to the bottom of my rad support.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
