09-17-2011, 08:22 PM | #1 |
LS Retro–fit Oil Pan Products
GM's popular LS engines are finding their way into a large variety of vehicles. They make great power, plus they're very durable and reliable. Unfortunately, the factory LS pans don't always fit or they hang too low for today's hot rods. Holley's LS Retro-fit Engine Oil Pan is designed to help! It provides maximum clearance to the chassis and ground, plus provides an OEM fitment for durability and proper sealing.
Features: Provides OEM fitment- OEM oil filter mounting, OEM oil cooler port provision, OEM engine NVH suppression, OEM flange gasket and sealing, proper structural rigidity and OEM bell-housing attachments. Traditional high-quality cast aluminum appearance with clean exterior styling. Provides maximum clearance to chassis Cast and machined aluminum Complete kit including sump baffle, pick-up tube, sump plug, oil filter stud & oil passage cover. Fits GM rear wheel drive applications that were originally equipped with a Small Block or Big Block Chevy engine and traditional rear sump oil pan* Sump Oil Capacity - 5.5 Quarts Total Oil Capacity with stock oil filter - 6 Quarts Requires use of a LS3 oil dipstick * Engine location may need to be adjusted (up / down or fore / aft) for cross member or steering linkage clearance depending on the vehicle, steering configuration and chassis type. Configuration: Traditional Rear Sump Layout External Sump Max Depth (from mounting flange) - 5.89" External Sump Length (from bell housing flange) - 7.65" External Sump Width - 9.75" LS Engine Retro-Fit Oil Pan Kit Fits 1955-1987 GM Muscle Cars/Classic Cars/Trucks Kit Includes: Sump Baffle, Pick-up Tube, Sump Plug, Oil Filter Stud & Oil Passage Cover. $395 shipped
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 09-17-2011 at 08:31 PM. |
09-17-2011, 08:33 PM | #2 |
Re: LS Retro–fit Oil Pan Products
Another Option is the GM unit:
Kit comes with the following items: 5 quart RWD oil pan Oil pick up tube and screen Oil pan gasket Oil pan bolts Windage tray Windage tray bolts Dipstick & tube $175 shipped
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
