Old 09-18-2011, 12:16 AM   #1
smilts60
sand blaster advice for working on my 60 stepper
I tried asking in paint and body no reply. But I bought this blaster kit http://www.ebay.com/itm/170693975294...84.m1439.l2649
got it and some fine black beauty blast sand. Problem Im havibng is it sprays for about 2 seconds then stops. I can let off of the trigger and re pull it and get another 2 seconds over and over but it wont keep a continuous spray. Ive tried the putting the pickup tube in the top of a bucket, and near the bottom sideways.
smilts60 is offline   Reply With Quote
Old 09-18-2011, 12:58 AM   #2
niterider65
niterider65's Avatar
Cool Re: sand blaster advice for working on my 60 stepper
whats the number of the sand?? sounds like the sands too big . ive used a #4 blasting sand it real fine .. where i work we rent sandblaster that can run black beauty thur it but the tip is like 3/8 and the pot is a 300 pound
with an 185 cfm compresser .. ive used some thing like this with # 4 silican sand not sure of spelling .. hope this helps
niterider65 is offline   Reply With Quote
Old 09-18-2011, 01:01 AM   #3
niterider65
also another problem can be humidity it will cause the sand to clump to gether .. or not enough air pressure .. hope it works out
Old 09-18-2011, 01:18 AM   #4
smilts60
Im starting to think along the lines of the sand not being fine enough. A little thinking has me believing that it starts fine then bigger pieces hit it and it clogs, I get off of the trigger and it clears rinse and repeat. Ill try finer sand. Thnx guys.
Old 09-18-2011, 06:50 AM   #5
Indian113
Indian113's Avatar
Do you ahve a drier in line? Dry air is real important with a sandblaster I run 2 one at my compressor and one before it goes into my sandblaster. I also drain my compressor before I start. You can buy driers at HF.
Indian113 is offline   Reply With Quote
Old 09-18-2011, 07:05 AM   #6
smilts60
Thats something I hadnt considered but i did feel a slight amount of moisture from the air nozzle.
