Old 09-18-2011, 01:11 PM   #1
dukcaln
dukcaln's Avatar
72 350 factory timing setting?
what was the correct factory timing setting for a 72 350 with 4bl and TH350 auto trans?
Also with addition of headers, small rv cam, and MSD electronic ignition set up what would most likley be a good all around timing setting for daily driving ad decent performance? I know every truck is different and will vary, but just a ball park at what setting people with similar set ups are running. Truck is ran at sea level for the most part...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 09-18-2011, 05:17 PM   #2
landsurvey1
landsurvey1's Avatar
Re: 72 350 factory timing setting?
I would start at 10 to 12 degrees btdc with the vacuum plugged at the dizzy, engine idle around 800 rpm. And then maybe 34 to 36 degrees @ 3600 rpm for advance.
landsurvey1 is offline   Reply With Quote
