Old 09-18-2011, 04:50 PM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
69 door panel nut replacement
So I`m in the process of replacing the interior of my 69C10, the nuts need to be replaced on the drivers door, I have the correct ones that insert from the inside of the door, how do I get to the one closest to the hinge? it has another piece of sheet metal over it on the inside?
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 09-18-2011, 08:04 PM   #2
JimKshortstep4x4
Re: 69 door panel nut replacement
I filed the hole so a square nut would fit and then welded it in place using a bolt to hold the nut in position.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-18-2011, 09:26 PM   #3
scotts72heavyhalf
Any chance a uy could reach in and get the nut out that fell in behind the hole?
Scotts72C10
Old 09-19-2011, 05:38 AM   #4
JimKshortstep4x4
You can try fishing around with a magnet.
Jim
Old 09-19-2011, 06:55 AM   #5
MikeyMan
Here's a tip I used:
I replaced the rusted and broken "nuts" in the doors with those square nylon/plastic license plate fasteners.
After stripping and drilling out the seized door panel screws, I just popped out the welded nuts. Then push in the square license plate nuts. They locked right into the square hole in the door. You can then "tap" new threads into the plastic by screwing in the bolt of your choice. I used stainless 1/4-20 screws with finishing washers. The finishing washers hide the rounded out door panel screw holes.
The plastic nuts will never rust, and only a buck or two for a set of four.
MikeyMan is offline   Reply With Quote
Old 09-19-2011, 10:50 AM   #6
camrycurt
camrycurt's Avatar
Hey MikeyMan,
That's a great tip! I've had some stripped door panel screws staring me in the face for about two months now because i wasn't sure what to do with them - now I know.
Thanks again!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 09-20-2011, 11:36 AM   #7
scotts72heavyhalf
That`s a great tip, I have a few of those layibg around. Thanks
Scotts72C10
