Old 09-18-2011, 06:07 PM   #1
heeroyue2002
fat old dude
heeroyue2002's Avatar
carbs and HEI
if the items fit in a medium shipping bix, which im sure most of these will. add 11 for shipping.
mallory HEI and a mallory COIL $75 pair!
next is a motorcraft carb manefactured by holley.
motorcraft e3zebgb
a3b24
$20!
qjet
7037219 nd
1182
$35!
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 11-15-2011, 08:09 PM   #2
heeroyue2002
fat old dude
Re: carbs and HEI
Must go! Make offer. No reasonable refused
Old 11-20-2011, 09:53 PM   #3
heeroyue2002
fat old dude
Re: carbs and HEI
ttt
Old 11-26-2011, 03:42 AM   #4
heeroyue2002
fat old dude
Re: carbs and HEI
bump! buy before it gets lost/or stolen in my move/relocation
Old 11-26-2011, 04:16 AM   #5
Bryon.Dillon
Bryon.Dillon's Avatar
Re: carbs and HEI
is the HEI for a 6 cyl?
Bryon.Dillon is offline   Reply With Quote
Old 11-26-2011, 04:38 AM   #6
heeroyue2002
fat old dude
Re: carbs and HEI
Im notsure. I believe 8 cyl and its also used on classic vettes
Old 11-26-2011, 04:44 AM   #7
Bryon.Dillon
Re: carbs and HEI
whats the part no on distributor?
Old 11-26-2011, 05:06 AM   #8
heeroyue2002
fat old dude
Re: carbs and HEI
38645c1
from my research they appear to go
for $400 new not including the coil. Those go for about $80 new
Old 11-26-2011, 03:49 PM   #9
Bryon.Dillon
Re: carbs and HEI
cant find any info on that model number, or i'd be interested. Not gonna take the risk that it wont fit my engine when i can get a whole hei setup that I know will fit for $150 minus plug wires. Thank you anyways =)
Bryon
Old 11-26-2011, 08:18 PM   #10
heeroyue2002
fat old dude
Re: carbs and HEI
what i found
Mallory #650-3864501
Corvette 1955-74 Tach Drive Distributor
Choose From Mechanical or Vacuum Advance
The Mallory UNILITE Electronic Distributor is triggered by a self-contained, photo-optic infrared L.E.D. system using Mallory's time tested breakerless ignition circuit, combined with modern surface mount Thermal-Clad construction that has no moving parts to adjust or wear out. The UNILITE infrared L.E.D. system can drive both original equipment and high performance ignition coils. A simple three wire hookup allows it to fit a wide variety of engine configurations and is designed for 12-volt systems. Mallory has precisely calibrated the mechanical advance (or vacuum advance) curve for normal driving conditions. However, the mechanical advance curve may be adjusted to meet your specific driving or racing requirements.
FEATURES: Improved combustion efficiency and economy. Increased spark plug life. Improved cold weather starting. Maintenance free operation. Accurate spark timing. Self-lubricating bushings provide years of trouble-free service.
Old 12-05-2011, 08:06 PM   #11
heeroyue2002
fat old dude
Re: carbs and HEI
Ttt
Old 12-13-2011, 08:25 PM   #12
heeroyue2002
fat old dude
Re: carbs and HEI
Buy
