Old 09-18-2011, 08:25 PM   #1
67Mach1
67Mach1's Avatar
Rear passenger LH removal
I need to pull this window out to put into another suburban. THis is how far I got before I had to stop. I actually didnt know where to go from here other than to remove the two screws or drill them out because one is stripped out.
Please help with information on how to get all the parts out in working order...
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 09-18-2011, 08:54 PM   #2
vectorit
What?
vectorit's Avatar
Re: Rear passenger LH removal
you have to remove the little 1/4 glass, and the channel that holds it in.
then it's just a matter of moving the big glass off it's bottom channel that raises and lifts, this is done by moving it back towards where the 1/4 glass was.
Once it's off the bottom channel, it's just a matter of angling it out from the out side.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-18-2011, 09:17 PM   #3
72ArizonaBurb
I removed mine without removing the small glass. Take all the screws for the window regulator out and get the glass out of the regulator. You can then rotate the glass while it is down inside the door and bring it out. It took me a little while to figure it out but I got it out. If you are parting out that burb you might as well pull the small window also and keep them for the future. You never know when you might need them.
72ArizonaBurb is offline   Reply With Quote
