Old 09-18-2011, 08:38 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
Getting ready to do a cab swap. What do I need?
hey,
I picked up a new cab for my truck and it's going to get some work done and then she goes on my truck.
Do i need to get specific mounting bolts or can i make something work from the hardware store??
Anything else that i should pick up that you guys can think of?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-18-2011, 08:46 PM   #2
85burb
85burb's Avatar
Re: Getting ready to do a cab swap. What do I need?
It really depends on the motor and trans it will be hooked up to. The best way to bolt it down would be studs. That is if it is a 4 bbl. Also may need some kind of trans linkage bracket. Most auto stores sell carb studs.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 09-18-2011, 09:41 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
A couple cases of beer and a few friends !!!
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-18-2011, 10:07 PM   #4
str8axle55
CAB swap, not carb swap. How are the body mount bushings? Same year cabs? Do you have 4wd or 2wd, and what does the new cab have, trans tunnel.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-18-2011, 11:27 PM   #5
85burb
85burb's Avatar
What a dumb a.. HAHA You may still need the studs for something.........
p.s. I had thought that was in the wrong section.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-19-2011, 01:29 AM   #6
pig rig
pig rig's Avatar
and be nice and put it on ice
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 09-19-2011, 03:43 AM   #7
cr34t3d_by_d4rkd3n
U really need to research the cab mounts. They are unaccessable from the nut so if u strip.. Gotta cut it out. What do u need? A forklift and soft staps will help u like no other. U realky just needbto search. Theres alot of work there man. Good luck.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 09-19-2011, 07:50 AM   #8
BigBlocksRule
Start by pulling the cab mount bolts in both of 'em, see what you have that will work. Most of 'em are junk as are the rubber mounts.
BigBlocksRule is offline   Reply With Quote
Old 09-22-2011, 03:01 AM   #9
willett
willett's Avatar
thanks for the input.
the truck is a '78 4x4 454 th 400 np203
the cab is a '73 2wd auto.
Old 09-22-2011, 07:47 AM   #10
BigBlocksRule
You're going to need some thicker body mount bushings, the hump in the floor of the 4x4 is taller than the 2wd to clear the t-case and whatnot.
Old 09-22-2011, 01:17 PM   #11
bigblock73
yeller
bigblock73's Avatar
No, he needs to modify the 73 cab to accept the high hump tunnel from his 78 cab.
You start raising the cab to clear the drivetrain, then you have to raise the front clip and bed too.
bigblock73 is offline   Reply With Quote
Old 09-23-2011, 01:26 AM   #12
willett
willett's Avatar
i was already planning to transplant the hump from my 4wd cab into the new cab. Its one of the only things thats still good in that old rust bucket
