![]() Join Date: Nov 2004
What yoke for a 700R4
My truck has had a 700R in it for almost 10 years.
The problem is that my yoke has become grooved, enough so that even a new seal didn't take care of it... and I have no idea what the yoke is from... I remember that my old 3spd manual yoke didn't work so I scrounged through a giant pile at a junkyard until I found one that would work with my shortened 67 driveshaft and I'm 99% sure 30 spline shaft 700R. I don't want to sleeve it... so what works? Would an automatic 67-72 truck shaft work? I think my yoke came from an 80's caprice, but I don't remember ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: What yoke for a 700R4
same yoke as TH350 and powerglide// should b about million of them in the junkyard
Yep-same yoke as TH350, Powerglide, TH200, TH200R4, TH700R4, 4L60, 4L60E, and Muncie 4-sp and most 3-sp manuals. What won't fit is TH400 or B/W car 4-sp. Not sure about HD granny gear 4-sp or TH375.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Great thanks guys!! What if I pull it and it's the 27 spline shaft... out of curiosity...
the boat guy
new trans yoke = time for a trip to the driveline shop for a ballance. They would also have whatever trans yoke you'd need and probably a new ujoint also.
Yeah, I planned on new U joints, but the balance is a good idea. It was balanced when I had it shortened (like 10 years ago), maybe it's gotten out of whack?
Hi,
Call these guys if you want a new one. They'll hook you up: https://www.drivetrainamerica.com/default.aspx If your seal gets old enough it will become hard and groove your seal surface. Nasty leaks after that, I hate it. |
Years ago I pulled the 3 spd installed the granny low top loader 4 spd the DS had to be swapped so your guess was correct.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
the boat guy
even if it was ballanced 10 min ago, if you're swapping parts you're changing the ballance.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
