Old 09-19-2011, 08:02 AM   #1
PCRedChev42
Noise troubleshoot
Hey guys,
I recently bought a 2005 Chevy Silverado 1500. This is my first truck and so far i have been doing good working out all of the problems, but i have recently run into a noise coming from the rear of the truck that I am having trouble figuring out. It almost sounded like a tick from an exhaust leak so when i parked the truck I hit the gas a little and it went away. Now the noise is almost a whine, but it only makes noise when im on the gas. There is no noise when Im coasting so I dont think it would be a bearing. One of my friends listened as i drove away from him and said that he believes it is coming from the passenger rear tire. If anyone has any thoughts please let me no. Thanks.
PCRedChev42 is offline   Reply With Quote
Old 09-19-2011, 02:57 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Noise troubleshoot
Is it only while you are moving? Could be somthing in the brake. Take it apart and see what you find.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-19-2011, 03:01 PM   #3
PCRedChev42
Yeah the only time I hear it is when Im accelerating. If I am coasting or slowing down there is no noise.
Old 09-19-2011, 03:08 PM   #4
usmcchevy
usmcchevy's Avatar
Jack it up and check/clean your brakes, I'd also pop the driveshaft off and check the U joints.
Build thread
LSx Swap FAQ index
Old 09-19-2011, 07:44 PM   #5
PCRedChev42
I checked my brakes and they were good and looked over my U joints. The the front U Joint on my drive shaft has some wet oil on the outside of it. It is supposed to be a sealed joint and has no grease fitting on it. There is also wet oil splatter on the underside of my cab right above the U joint and around the sides of the joint on my frame. So my guess is that it may be that U joint. If anyone has any thoughts please let me know.
Old 10-03-2011, 09:33 AM   #6
PCRedChev42
Two weekends ago now, I pulled the driveshaft out of my truck and looked at both U joints. Turns out that the rear joint on the shaft was broke. while i had the driveshaft out, I decided to replace both joints. I have benn running the truck for a week now and the noise is gone. Thank you guys for your help.
