Old 04-12-2003, 09:50 AM   #1
lotik
drag it like you stole it
quick question again
if i welded a piece of tubing from one trailing to the other horizontally, would they still function the same?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-12-2003, 10:20 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I don't think you want something rigid between them, they need to be able to flex independently of each other for uneven surfaces.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-12-2003, 11:10 AM   #3
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
No they won't. You would loose articulation (sp). When one wheel went up or down due to road inconsistancies, the other would do the same. It would be funny though, to see you bouncing all over the road As long as no one got hurt too badly
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 04-12-2003, 02:18 PM   #4
minibike
minibike's Avatar
It would depend on where it was at. If it were right under the axle, it shouldn't make a difference, but further up could cause problems.
The reason I say this, is the axle is rigid between the control arms, so I don't see what difference a bar would make there. The arms have to twist a little further up to allow one side to travel more than the other.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 04-12-2003, 08:36 PM   #5
Blue Beard
Blue Beard's Avatar
The June Classic Trucks has a article on strengthening them....................Just pick it up................
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-12-2003, 08:36 PM   #6
Blue Beard
Blue Beard's Avatar
The June Classic Trucks has a article on strengthening them....................Just picked it up................
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
