Old 09-19-2011, 12:34 PM   #1
hb32
hb32's Avatar
55 front fender mounting
Looking for pictures or a source for the attach hardware to bolt the lower part of my front fender by the door. Previous owner decided to weld the fender to the sill for some strange reason and I need to reattach it properly. Not having any luck with google or the parts places.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 09-19-2011, 01:06 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 55 front fender mounting
Post a picture of what you have and we can tell you what you need.
dwcsr is offline   Reply With Quote
Old 09-19-2011, 05:02 PM   #3
hb32
hb32's Avatar
Here is what it looks like.
Old 09-19-2011, 06:13 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can weld a flat plate with a nut on the inside to bolt it to the cab. What does the lower cab pillar look like, The part that fender bolts to?
Old 09-19-2011, 06:24 PM   #5
OrrieG
OrrieG's Avatar
There is supposed to be a capture nut in the square hole location. A bolt runs thru a rubber grommet in the frame tab (see photo below) to the captured nut. It can be shimmed to align with the door and cab sill. I don't have a photo of the inside of my fenders.
OrrieG is offline   Reply With Quote
Old 09-19-2011, 07:39 PM   #6
hb32
hb32's Avatar
There is no problem with the cab side only missing what is suppose to be on the fender.
Old 09-19-2011, 09:49 PM   #7
hb32
hb32's Avatar
Thats the part I am trying to locate, the captured nut.
Old 09-19-2011, 11:33 PM   #8
hb32
hb32's Avatar
Found a pic on another forum and they are called "capture nut" Anyone have a source?
Old 09-19-2011, 11:42 PM   #9
Rude Dude
Rude Dude's Avatar
Here is one
http://www.classicparts.com/Patch-Pa...oducts/153/4/0
Rude Dude is offline   Reply With Quote
Old 09-20-2011, 01:31 AM   #10
OrrieG
OrrieG's Avatar
Someone here was building their own because they could not find them either, but I can't remember who. They tapped a piece of square stock and made the "cage" out of 16 ga or so material. Maybe an advanced search will turn it up? This might help too:
http://67-72chevytrucks.com/vboard/s...t=captured+nut
