Old 04-12-2003, 10:54 AM   #1
1969 4x4
advice??
hey guys.. i am doing the same thing with a 72 chevy.. i have a 4x4 frame all blasted and apart... i also have a 72 chevy 4x2 i just bought from a board member. that frame looks very clean and the body is already on it.. It is a coil all around truck.. what will be easier and fastest to do.. i need help thanks
1969 4x4 is offline   Reply With Quote
Old 04-24-2003, 12:36 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
I guess you are trying to make a 4x4? You are on the right track with the new frame.
Don't even think about changing the 2x4 frame over. They are really different.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 04-24-2003, 10:14 PM   #3
Bob Chayer
Swap the body onto the 4x4 frame. It's a direct bolt on but make sure you use the 4x4 body mounts as they are different.
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
