Old 04-12-2003, 11:13 AM   #1
400ex
what type of fan
I want to install an electric fan in my '71 1/2 ton. The problem I'm facing is limited space between the radiator and water pump pulley. I measured a Lincoln Mark VIII fan+shroud but it was too wide for the gap. I have only about 5" of room to play with.
What type of electric fan do you guys use; the entire depth has to be < or = to 5"?
I would prefer a stock type fan and shroud because the fans without the shroud don't really work in my opinion.
Thanks,
James
400ex is offline   Reply With Quote
Old 04-12-2003, 12:15 PM   #2
krue
Designated A-hole!
krue's Avatar
do a search, there was a thread on dual fans posted by dubie on 3/30. I'll just ttt for you. Maybe it will answer your question?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-12-2003, 03:48 PM   #3
trailwart
trailwart's Avatar
i seen a set up out of an early camaro (90,91) i think was the year of the set up
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 04-12-2003, 05:05 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Ours are 4 3/4" deep over all. They won't even be that deep once it is installed depending on the manufacturer of the radiator you have. Here is a picture of the duel 12" stainless steel assembly that we offer. It comes with everything you need for instalation including the thermostat. Here is the link: http://www.classicheartbeat.com/new_products.htm
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-12-2003, 05:13 PM   #5
Low69CST
Flexalite, built well, easy to install, cools great and $220bucks ( i think) and very slim.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-12-2003, 06:02 PM   #6
XXL
Seņor Member
XXL's Avatar
Has anyone mounted an electric fan at the end of the stock fan shroud before? It seems like that would be nearly ideal, as it would create a manifold from which to pull air in across the whole radiator.
Just thinking out loud here...
Kenneth
XXL is offline   Reply With Quote
Old 04-12-2003, 10:06 PM   #7
383 Stroker
383 Stroker's Avatar
I'm using a mid 90's Crown Vic fan. It's 4" deep. The fan is 19" Here's a picture.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 04-12-2003, 10:07 PM   #8
383 Stroker
Another Picture.
Old 04-12-2003, 10:25 PM   #9
70c10
67-72 Addict!
70c10's Avatar
383stroker, that looks great!, where did you get that top radiator cover?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-12-2003, 10:41 PM   #10
383 Stroker
Thanks 70c10, I got it from a local metal shop. It came from a sheet of aluminum, I told them the size I wanted and where to bend it.
