Old 09-19-2011, 04:30 PM   #1
Lextech
Lextech's Avatar
A/C Vents
I think I will close up the radio hole in the dash and would like a center vent there. What are you guys using for vents? This would be for an AD truck, but post anything you have. It is not that I am too cheap to buy the billet ones. aI just would like the vents to look like they belong there.
Jeff
Lextech is offline   Reply With Quote
Old 09-19-2011, 05:39 PM   #2
mknittle
mknittle's Avatar
Re: A/C Vents
how about making a chamber that vents through the speaker grille?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-19-2011, 09:03 PM   #3
youngrodder
youngrodder's Avatar
Re: A/C Vents
I used some from Vintage Air. They are chrome, round (which I think goes good with the round shapes in these AD trucks) plus they were only $10 each...
Here is a link to the web site.
http://www.vintageair.com/catalog11/pg53wc.pdf
I used Prt # 490535 Double vane louver chrome. But there are others as well.
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-20-2011, 08:22 AM   #4
Lextech
Lextech's Avatar
Re: A/C Vents
I thought about putting the center vent in the speaker grill. I also like those round A/C register/vents. Maybe I will do both. My truck is a 54---Which I really like. BUT, I Hate the 54 dash. I just got a 53 dash to retrofit. I am thinking of removing the ash tray and moving the glove box to the left and relocating the headlight switch. Then I would have enough room to have vents on the dash next to the gauges and next to the glove box. I have to give it some more thought.
Jeff
Old 09-20-2011, 11:12 AM   #5
skip99
skip99's Avatar
Re: A/C Vents
I built mine into the dash at thr bottom, check the build
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 09-20-2011, 12:55 PM   #6
Lextech
Lextech's Avatar
Re: A/C Vents
Hey Skip,
I have checked out your thread several times---Very Nice. I am still in the thinking about stage.
Jeff
Old 09-20-2011, 03:52 PM   #7
mknittle
mknittle's Avatar
Re: A/C Vents
Jeff
That's so cool about metal there are so many possibilities.My biggest problem is deciding on just one.
Mark
My GMC build.
Old 07-25-2013, 08:58 PM   #8
MIKEs50Chevy
MIKEs50Chevy's Avatar
Re: A/C Vents
Anyone have any other suggestions for vents behind the original dash speaker location? I'm installing a Vintage Air system and we've removed the center vent and used that space to install the control for the SecretAudio stereo system. I would still like a center vent for the heat and a/c. Any ideas on something that I can use behind the dash speaker grill? I'd prefer to be able to open and close it but that might be asking too much.
MIKEs50Chevy is offline   Reply With Quote
Old 07-26-2013, 08:44 AM   #9
mknittle
mknittle's Avatar
Re: A/C Vents
Mike can you post a picture of what you have to work with? it would be a big help!
Mark
My GMC build.
Old 07-26-2013, 11:40 AM   #10
hotrodsbyray
Re: A/C Vents
60's t-birds had a neat double center vent that used a single knob to control the up-down and side-to-side movement of each vent. You see them on e-auction now and then. Might could be adapted in or below dash.
hotrodsbyray is offline   Reply With Quote
Old 07-26-2013, 06:58 PM   #11
MIKEs50Chevy
Re: A/C Vents
I don't have a picture of the spot, but it's the stock dash speaker spot that I'm trying to put a vent into. Does that make sense? I took out the original radio and speaker combo and rather than just have a blank space behind the speaker grill in the dash, I'm hoping to come up with a way to run a vent there but I'd really like to be able to adjust it and maybe even close it (in a perfect world). :-)
Old 07-27-2013, 05:44 PM   #12
solidaxel
solidaxel's Avatar
Re: A/C Vents
That is what I did on my green truck, I think I mounted Chevelle defusers behind the grille
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-29-2013, 08:58 AM   #13
mknittle
mknittle's Avatar
Re: A/C Vents
Yeah, I was just wondering how much room you have. With everybody doing different things no two are alike.
Mark
My GMC build.
Old 08-01-2013, 09:11 PM   #14
MIKEs50Chevy
Re: A/C Vents
Here is a picture showing the open speaker grill in the dash. In the bottom of the picture you can see where the control unit for the SecretAudio has been installed in the middle vent. Any suggestions would be appreciated.
