Old 09-19-2011, 04:51 PM   #1
oily
diesel swap
I have a 83 GMC van with a inline 250 .
What are the options for swapping a small inline 6 diesel?
I once saw a 1960-70's ford half ton with a inline 6 diesel and it was impressive . Prolly a Cummins.
oily is offline   Reply With Quote
Old 09-19-2011, 07:58 PM   #2
muddyblazer02
muddyblazer02's Avatar
Re: diesel swap
The problem you are going to run into in a half ton truck is weight. A diesel six cylinder, even a small one, is much heavier than a v-8 which in it self is heavier than a 250 inline. Also frame twist is going to be a problem because the torque in a diesel is higher. so if you can address those issues then your golden. A 4 cylinder cummins would be an easer swap in my opinion.
Ken
truck junkie
muddyblazer02 is offline   Reply With Quote
Old 09-19-2011, 11:18 PM   #3
BigRed76
BigRed76's Avatar
Re: diesel swap
I don't know of any "small" 6 cylinder diesels physically they are all pretty big. But you can stick a 12 valve Cummins in ANYTHING...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-20-2011, 07:35 AM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: diesel swap
a 4BT is an exellent choice for a half ton truck, the only problem is that more people are realize'n this and the cost has really shot up for em.
theres alway's the 6.5 turbo, they can produce decent power and would be the easyest to swap into your truck.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 09-20-2011, 11:41 AM   #5
BigRed76
BigRed76's Avatar
Re: diesel swap
Well said. The only reason I'd go with a 6 cylinder diesel is to be different. A 6.2 or 6.5 swap would be the easiest, although the 4BT's are pretty neat and only weigh as much as a big block
Zach
Old 09-20-2011, 12:29 PM   #6
ky_kid
ky_kid's Avatar
Re: diesel swap
I have also been considering a diesel swap. I don't do any towing I really just want the fuel mileage. I know where I can get a 6.2 for a good price with hardly any miles on a rebuild. How hard would I be to swap into an 84 K10? I'm currently running a 350 crate engine with a 4L80E. I wasn't sure if my truck could handle the weight.
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 09-20-2011, 01:13 PM   #7
BigRed76
BigRed76's Avatar
Re: diesel swap
I know that in the 80's you could get a 6.2 in a half ton from the factory. Not sure if they had some stronger springs in the front. A 6.2 will fit fine because it is a factory motor. You will basically need the entire underhood wiring harness for the 6.2. And I'm sure the fuel lines are different too.
Zach
Old 09-20-2011, 02:00 PM   #8
ky_kid
ky_kid's Avatar
Re: diesel swap
Would my truck really be that much slower if I did the swap? I am really only after the fuel milage but wouldn't want a slug. I runs great now but I only average 12-13mpg at best.
Also, what are good 350's selling for? It's a GM crate with around 30k on it with all new accessories.... Trying to decide if this would even be a smart financial move (I plan on keeping this truck a long long time)
Old 09-20-2011, 03:07 PM   #9
Your41Plague12
Your41Plague12's Avatar
Re: diesel swap
You could probably get about $1200 for that engine. If you're honestly getting 12 or 13 mpg from a 350, you're doing awesome. The diesel will be a dog compared to the 350 (if the diesel is stock), but it will be close to doubling the fuel mileage (20-22 mpg). If you're building for economy, the diesel is the way to go, but don't expect to get anywhere fast.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-20-2011, 03:10 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: diesel swap
you would have to keep the truck a long time to see any finacial gain after the money to do the swap, there's a lot of little crap that will have to be change'd.
the best thing would be to find a donor truck with a diesel so you have evry thing there.
I bought one of my son's a '84 K10, 6.2 4speed. it got close to 25 mpg. and I gave $2000.00 for the truck.
you wont smoke the tire's with a stock 6.2, but it will keep up with traffic fine.
'85 1/2 ton CCSB
'92 S10 350/350
Old 09-20-2011, 03:10 PM   #11
ky_kid
ky_kid's Avatar
Re: diesel swap
Sounds like I should stick with the 350, it runs great and the milage isn't too bad I guess. I just like diesels so I was curious.
Old 09-20-2011, 04:13 PM   #12
Urban Suburban
Re: diesel swap
i am new to this diesel thing but I don't find the 6.2 too bad compared to my old 350 Burb its a little slower but a ton better on fuel. I wouldn't wish the 350 back myself.
Urban Suburban is offline   Reply With Quote
Old 09-20-2011, 04:24 PM   #13
ky_kid
ky_kid's Avatar
Re: diesel swap
I definitely like the idea of diesel. I think if I found someone to buy my engine I would try the swap. If it was too slow I guess I could always turbo it!!
Old 09-20-2011, 06:37 PM   #14
BigRed76
BigRed76's Avatar
Re: diesel swap
I would imagine a turbo kit will just bring the fuel mileage down. It will make it faster (if it can handle it), but more air into the engine = more fuel into the engine.
Zach
Old 09-20-2011, 09:47 PM   #15
oily
Re: diesel swap
Well if I saw it in a 70s Ford it wasnt stock.
The only small I6 diesel back then was a mitsubishi 6dr50a, which is rare.
Trouble with I6 diesel is the deck height because of long stroke.
Tough in a van.
ps the cummins fully dressed is 1000 pounds [internet]
Old 09-20-2011, 10:22 PM   #16
BigRed76
BigRed76's Avatar
Re: diesel swap
Yeah the deck height would surely cause problems in the van. Even the 4BT wouldnt help because its the same as the 6 cylinder cummins, just has 2 cylinders cut off.
Zach
Old 09-20-2011, 11:01 PM   #17
Edahall
Re: diesel swap
With a set of headers and free flow exhaust on a 6.2L, it won't be slow.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-20-2011, 11:56 PM   #18
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: diesel swap
You got it backwards... turbo's HELP diesels burn their fuel better. Better fuel burn = better fuel mileage. There are things to watch out for and more things to keep track of, but every 6.2 would benefit from having a turbo. You just can't go crazy with it and stomp on the throttle every time you want to get somewhere.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 09-21-2011, 12:30 AM   #19
Edahall
Re: diesel swap
The biggest issue I see with adding a turbo on a 6.2L diesel is engine longevity. The bottom ends are just are not strong enough to support that much power. These engines were designed to get excellent fuel economy in a 1/2 ton truck and they did very well at that.
Old 09-21-2011, 01:24 AM   #20
1973GMC_1500
1973GMC_1500's Avatar
Re: diesel swap
Actually, fuel lines are the same for the mechanical pump. Depending on your fuel filter setup on the 6.2, you may not have to change anything (I didn't when I went from 6.2 to 350 in my 87, currently going back to 6.2).
Wiring is the same for starter, alternator, and you could probly make the oil and temp gages work with the gassers wiring. All a 6.2 needs to run (besides glow plugs) is one key on 12V wire to the injection pump. Glow plugs are easy enough to wire yourself, by using a pre-85 relay and manual pushbutton.
'87 GMC K2500 Factory 6.2 Diesel, 4 speed. Converted to 350 (has cracked block) converting back to 6.2
'82 [COLOR="Sienna"]Cadillac Coupe Deville 350 DIESEL
'93 Chev S10 2.8L 5 speed
'98 GMC K1500 Z71 ext cab shortbox 6.5 DIESEL
'96 Ford F250 7.3 Powerstroke
1973GMC_1500 is offline   Reply With Quote
Old 09-21-2011, 03:02 AM   #21
lindstromjd
Re: diesel swap
You can get a stud kit to really help strengthen them up. I think ARP sells a kit for the main girdle on a 6.2...
-357 / 700r4
-350 / TH350
Old 09-21-2011, 07:08 AM   #22
BigBlocksRule
Re: diesel swap
Leave the gasser in it, loosen the rocker nuts and put some Limburger cheese on the exhaust manifolds.
That way it'll rattle and stink like a diesel with none of the headaches of the swap!
BigBlocksRule is offline   Reply With Quote
Old 09-21-2011, 09:15 AM   #23
Edahall
Re: diesel swap
Both of those items are band-aids and not fixes to a weak bottom end design. They may work but I still would not trust it to hold long term on a high performance turbo 6.2L. Remember, the original red 1982 6.2 block which also is one of the strongest out there due to the high nickel content was only rated for 130 hp / 240 ft-lbs torque. It did not make much power but it got very good fuel economy and they lasted forever if maintained. Over the years, power increased and fuel economy and longevity nose dived. I've got a 1982 6.2L Suburban with nearly 500k miles on the original engine and if driven conservatively, it'll manage 30 mpg. Stock form, it was extremely slow so I installed headers and a free flow exhaust. The difference was like night and day and I gained a little on fuel economy as well. It has plenty of performance to maintain all the speeds on the highway including the 80 mph speed limits in Texas. I also tow a 26' Airstream behind it. It doesn't keep up with the big boys but it does get the job done.
Old 09-21-2011, 07:22 PM   #24
oily
Re: diesel swap
Maybe this is suitable: Cummins/Onan 6AT3.4
"I believe that most if not all of them that came out of a bread van have the SM465 transmission so if you got a Chevy bell housing I think you would be okay. "
http://www.4btswaps.com/forum/showth...-6at3.4-nv4500
Old 09-22-2011, 11:49 AM   #25
ky_kid
ky_kid's Avatar
Re: diesel swap
What headers would you suggest? I'm only seeing the Hummer headers and they're a bit pricey.
