Old 09-19-2011, 09:34 PM   #1
flip66
flip66's Avatar
396 to 400
Can you interchange parts (heads, intake, cam,) between a 1969 396 with a 71-72 402. In other words are the blocks the same, I have 396 that is blown, not sure how bad yet but want to be ready when I get it apart.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 09-19-2011, 10:19 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: 396 to 400
I think a 402 is just a .030 over 396.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-19-2011, 10:47 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: 396 to 400
This is correct
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-20-2011, 07:28 AM   #4
70GMCBB
Re: 396 to 400
I have a 70 GMC that the block ID indicates it's a 402. It sold advertised as a 396 in the day. I originally thought it was just bored over 0.030 also but my machine shop guy said they had casting for a 402 also. Personally don't know if they did. All parts except pistons of course will interchange.
70GMCBB is offline   Reply With Quote
Old 09-20-2011, 07:53 AM   #5
MARKDTN
Re: 396 to 400
x3
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-20-2011, 08:16 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
Re: 396 to 400
the story on the 402 GM had a lot of 396 blocks that would not clean up to 396 and there where a lot of them 25K of them dam critters.Back in the day Most company's where not into waist.And sence the block could be used again like a 350 going from stock to 3.55 it just made sence.Now here is a Peace of evidence the 1970--72 Monte Carlo only had 2 options of engine's the 350 and the SS 454 But i've found a few that had the 402 in them.I did research on this GM had a lot of these blocks and they where trying to throw them into as many trucks car's and motor homes as they could before the 454 was a real option..The 402 was a mistake But instead of Gm just junking them they made a profit.Most of are trucks have the 400 logo on the side of are trucks that logo was stolen from the Blazer 400 small block GM did make a limited run of the 400 big blocks.But never put them in any production car's I've never seen one But i hear most of them where used in Race Car's.
Its funny you read all you can about the MONTE Carlo and it started in 1970 when the 402 came about.One guy did say this about the Monte Carlo.It had very low numbers of productions in its first 3 years.From out of them 3 years only 6XXX Monte's had the SS option the option was the 454 Now that was a LS 6 motor Now some of them had the dealer add on alum heads making it a LS 7 motor with alum intake a Holley carb and I've seen 3 of them.
But the real truth in it When i bought 2 Monte Carlos they both had big blocks in them and i thought i hit pay dirt But with the SS Monte Carlo had bucket seats and shifter on the floor the 2 i bought had bench seat and column shifter.Pulled the motor out they had the casting numbers for the 396 and casting numbers of another block but none of my books listed it until 1977 most of them refer to the 396 casting
stsalvage is offline   Reply With Quote
Old 10-04-2011, 10:42 PM   #7
68Gold/white
Re: 396 to 400
Sounds resonable to me.
I heard a story, that the 396 was punched .030 over to a 402 to help pass an emission test.....who knows...I'm not an expert...
68Gold/white is offline   Reply With Quote
Old 10-04-2011, 11:26 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 396 to 400
there's a few stories, none can be 100% verified. inner office politics (not wanting a small block to be bigger than a big block) smog regs, a bunch of blocks not being cast properly... those are the 3 main ones I've heard... in the order that I believe. (I basicly don't believe GM had 25000 blocks before they 'noticed' a mistake) I also question this blazer 400 small block?
A 402 and a 396 are the same except the pistons, rings, and I think there was a couple other odds and ends. Most (if not all) the blocks share a casting number.
Old 10-05-2011, 07:04 AM   #9
Re: 396 to 400
Some 402s are over bored 396s and the rest are their own casting from what I know. So,as said,the pistons & rings are the only thing not compatible from a 396. I won't profess to know how or why GM did anything they did,but it makes sense to me that the 396-402 is no different than the 283-307,327-350,or for that matter,the Ford 289-302,the Chrysler 273-318,etc. Engines grew for more power through the '60s and I figure by the time emission standards were mandated in the late-60s they grew just a tad more to compensate for lowered compression and smog pumps.
Old 10-05-2011, 03:36 PM   #10
custom1970
Member
custom1970's Avatar
Re: 396 to 400
I remember reading a while back that the reason for the 402 was because of the 1970 Clean Air Act. In the act there was an exception for trucks with engine over 400 cu in. Therefore if GM keep putting 396's in the trucks they would have had to of added all the pollution control systems to make the engines conform to the law. So, it was cheaper to make the 396 a 402 than ad smog equipment.
Would like to know if this is true or just an urban legend or what....
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 10-05-2011, 05:13 PM   #11
406 Q-ship
406 Q-ship's Avatar
Re: 396 to 400
Sorry but I call BS on the whole thing. The .030 over bore on the 396 to get it to 402 was an emission deal for California as I understand. If it was the left over bad 396 blocks, then wouldn't people be pulling engines with casting dates of 1965 as an original 402 in a 1970 Chevelle, Camaro, Nova, Impala, and trucks. So it was a planned deal.
On the Monte Carlo you are so far out from reality. I am the owner of a 1971 and have had a love for the Monte since my Grandfather bought a brand new one in Sept 1969. The 402 was an optional engine in the 1970-72 Monte Carlos. There are NO LS-6 Montes, not from GM ever!! (No 4 speed SS454 either in 70 or 71) All the SS454 Monet Carlos in 1970 and 71 have LS-5's in them. The 1972 Monte Carlos is curious in that there is no SS454, but the 454 was available in them as an optional engine (the 402 just carried on as an option). Aluminum heads do not make an LS-6 into an LS-7, two completely different engines. There is some conjector on whether the L89 option was ever delievered on one perticular 1970 LS-6 Chevelle (it seems there was an overlap of the LS-6 and the L89 aluminum heads for a very short window). Did a dealer install an LS-6 or LS-7 in a Monte Carlo SS454, quite possibly, but Chevrolet did not do it.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 10-05-2011, 05:45 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Re: 396 to 400
ive heard all of these stories too. i think people will believe whatever they want, so i say pick whichever one sounds best!
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
