09-19-2011, 10:25 PM | #1 |
Cab mount bushings
Is it possible to change the cab mount bushings without taking the cab all the way off?
Thanks Larry |
09-19-2011, 11:32 PM | #2 |
Re: Cab mount bushings
Yes..
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
09-20-2011, 09:22 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
from what I was told by some one who has done it many times, it is best/easier to do them by the side. left side then right side. I havent done it but this is what I was told. use a floor jack and a block of wood to prop the body up.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-20-2011, 10:24 AM | #4 |
Thanks. Will do that.
Larry Posted via Mobile Device |
09-20-2011, 02:04 PM | #5 |
It's Better With Nitro
X2...this is what I did almost on a daily basis while mocking up chassis.
09-20-2011, 02:28 PM | #6 |
what mounts do you guys like rubber or poly?.....dan
09-20-2011, 02:31 PM | #7 |
I have heard that poly squeak unless you grease often, I like the rubber myself.
09-20-2011, 02:33 PM | #8 |
thanks clyde,i'll go with rubber!do you think that goes for motor/tranny mounts as well?
09-20-2011, 02:56 PM | #9 |
Well Oldtrux, I went with rubber all around. Front and rear suspension, cab mounts and everything. Some will say poly is great but I am not a fan. I have "0" squeaks period. That is why I did all the bushings, I hate squeaks.
09-20-2011, 03:12 PM | #10 |
i hate squeeks too!!i'll follow your lead with rubber as well!thanks clyde
