Old 09-20-2011, 03:17 AM   #1
huero
1969 Short, Fleet, and Beat
huero's Avatar
What is this?
Anyone know what this is on the master cylinder line?
huero is offline   Reply With Quote
Old 09-20-2011, 06:28 AM   #2
jim zag
ENGINE BUILDER
jim zag's Avatar
Re: What is this?
Probably had a hydraulic trailer brake controller set up in the past.
JIM ZAG
jim zag is offline   Reply With Quote
Old 09-20-2011, 06:55 AM   #3
Re: What is this?
X2. You could remove both pieces and eliminate two possible leak areas,but would need to bleed system. I guess if it ain't broke...
Old 09-20-2011, 08:35 AM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
Re: What is this?
the things you find on trucks. I've seem some good stuff.But lately its been getting better from some of the car's and trucks
stsalvage is offline   Reply With Quote
Old 09-20-2011, 09:40 AM   #5
RustyParts
RustyParts's Avatar
Re: What is this?
Looks like the proportional valve is on upside down and plumbed wrong.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 09-20-2011, 01:50 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
Re: What is this?
good catch, it's a 69 (if it's the truck mentioned by his username) drum drum trucks had distribution blocks not porportioning valves. It doesn't hurt anything but it's definetly wrong.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-20-2011, 08:35 PM   #7
huero
huero's Avatar
Re: What is this?
You are correct. Drum/drum.
I thought it was pretty interesting, now I know what it is.
Thanks guys.
Old 09-20-2011, 08:58 PM   #8
mrhino
Re: What is this?
I could be wrong But I think its some dill hole's attempt to plug a fitting that don't belong there in the first place.
mrhino is offline   Reply With Quote
Old 09-20-2011, 09:00 PM   #9
1972RedNeck
1972RedNeck's Avatar
Re: What is this?
Fix it 'till it is!
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-05-2011, 04:41 PM   #10
Markedz
Re: What is this?
Maybe that part is part of an old line lock system for the front brakes so you can smoke the rear tires until you're blue in the face. Is that distribution block upside down though?
Markedz is offline   Reply With Quote
