Old 09-20-2011, 11:16 AM   #1
rsavage
rsavage's Avatar
Carpet Strip Substitute
Not an original idea of mine but perhaps worth regurgitating. Carpet strips for Blazers and Burbs are hard to come by and are usually in poor condition when you find them. I bought a couple of polished stainless steel bed repair strips without holes for $20 each through LMC. Here are a couple of photos of one next to my rear carpet strip. The bed strip is about 1/16" wider. It appears my Blazer tailgate seal weather strip will work under the hump.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-21-2011, 12:42 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Carpet Strip Substitute
Pretty cool! Do they come long enough to span across the whole floor?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-21-2011, 01:14 PM   #3
nightmare
nightmare's Avatar
Always a good idea. By the way, what are the dimensions between the mounting point on the strip?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-21-2011, 04:44 PM   #4
rsavage
rsavage's Avatar
The original rear strip is 63 3/4" long. The polished stainless bed strip is about 97" long so it is well over what is needed. The hole spacing on the original is as follows looking at it from the back of the Blazer and going left to right:
holes on each of the two ends are 1/2" on center from their respective outside ends. Starting at the center of the first screw hole on the left, the remaining holes are 7 1/8 " on center from the hole to the left. There are a total of 10 holes overall. The second last one ends up being 6 5/8 " on center from the outer right hole (go figure?). I do not have a factory front strip so will make spacing match the factory rear that I do have.
1961 C1 Corvette
2021 Durango RT 5.7
Old 09-21-2011, 06:54 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
Thanks, rsavage. I never thought I'd have hold downs, but now this makes it possible!
1970 2wd Blazer
Old 09-25-2011, 09:04 PM   #6
Big Block
Big Block
Big Block's Avatar
Thanks for posting. Great ideal.
Big Block is offline   Reply With Quote
Old 09-25-2011, 09:55 PM   #7
my90k5
72 K/5 Junkie
my90k5's Avatar
My original front and rear strips are identical. Nice find.
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 09-25-2011, 10:11 PM   #8
bigbadchev72
People know me
bigbadchev72's Avatar
Got mine installed this weekend, looks great!
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 10-03-2011, 10:36 PM   #9
hotrodhomi
hotrodhomi's Avatar
I think I have one of those in my garage if you need it.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-03-2011, 10:48 PM   #10
bigbadchev72
People know me
Here is a pic of mine installed
Also Here is a substitute for the front strip as well, You can buy a new one of these for about the same price an original that needs re-chromed or powdercoated. I would doubt that anyone but a well knowledged purist would even notice.
I bought mine at a yard sale for $3, but it is for the front of a pickup bed. Here is a link to one, it runs about $50
http://www.buyautotruckaccessories.c...head-bed-caps/
Here it is installed
Old 10-04-2011, 05:25 PM   #11
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
bigbad- this is not mounted far enough back if you are wishing to install the tailgate seal. I think the polished ss strip would look good if someone used then for the vertical part of the tailgate seal since that is a hard to find blazer only part, and never came shiny.
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 10-04-2011, 06:52 PM   #12
bigbadchev72
People know me
I dont intend to run a seal on mine, I just wanted a finished look and something to hold down the carpet. I would like to see the verticals as well.
