09-20-2011, 04:50 PM | #1 |
Bonneville & Drag Strip Push Truck questions
Hey guys,
Since the guys at my shop are all building Pro Street and Drag vehicles I was thinking of making mine into the shop's Push Truck. All of their trucks and cars have a radiator so it's not like they can't motor back under their own power but I thought it'd be cool to have that shop truck look with a push bar in front. Question is what's the best way to mount the push bar? Anybody have pictures or descriptions of how to mount one? I don't want anything too bulky as this will still be a routine if not daily driver. Help me out, give me some inspiration here
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348 2001 Suburban daily driver 2008 HHR (wife's ride) |
09-20-2011, 10:14 PM | #2 |
Re: Bonneville & Drag Strip Push Truck questions
Fab some brackets using sections of a spare bumper as the base for your 'push-bar'. Then you can simply attach it using the OE front bumper/frame holes for easy on/off w/o changing anything else.
Many old push trucks used simple round tubing on the ends (an oval the width of the frame rails) or a big piece of wood.
09-21-2011, 10:42 AM | #3 |
I took a few of this truck at the Beech Bend Hot Rod Reunion. I have always wondered the same thing and captured it for my memory. I thought this was a well thought out and had clean finish.
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
09-21-2011, 10:52 AM | #4 |
Hey thanks for the replies guys
In the picture above the red truck's push bar appears to run under the bumper? Is that attached to the frame somehow do you think? Maybe they just drilled holes and mounted through the frame like you would do with a reciever hitch on the other end?
09-21-2011, 05:24 PM | #5 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
09-23-2011, 07:41 PM | #6 |
Just a picture from my files. Sorry, no details.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
09-23-2011, 09:08 PM | #7 |
1961 crewcab
old amt model kit:
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-23-2011, 10:07 PM | #8 |
He lives in my area but I'm not sure on the details for the 'push-bar' set-up.
09-24-2011, 10:08 PM | #9 |
Thanks for the pics guys. That one on the white truck is cool but seems complicated lol
