Old 09-20-2011, 06:16 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
Static or Bags
I would like some help deciding if i should bag my new longbed truck or do a static drop. I have a 700r4 with a big block. i do what to use the new shock relocation kit from No Limit and a few of their other parts but i cant decide on springs or bags
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 09-20-2011, 07:57 PM   #2
robnolimit
robnolimit's Avatar
Re: Static or Bags
I hear ya. We're swapping the JT to air soon, droped with springs has a tough time when we go to powder coat or the welding shop with a load of gas bottles. I like Early Classics springs the best, but we are working on getting some made, but it's a ***** getting what we want, and I'm just not willing to go to china to be price competetive. Either choice, use the best parts and you'll be happy.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 09-20-2011, 08:56 PM   #3
1971ls1longbed
Re: Static or Bags
As far as the best parts go thats why i want to use alot of your parts but again im not sure how nice a ride is with bags is and i dont know how well it will perform if i push the truck hard
Old 09-20-2011, 09:00 PM   #4
1971ls1longbed
Re: Static or Bags
oh and can you send me the link to JT i cant seem to find it
Old 09-20-2011, 10:03 PM   #5
SCOTI
SCOTI's Avatar
Re: Static or Bags
Do both. Static drop the front & swap bags into the rear so you can be low & adjust for capacity when desired.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-20-2011, 11:08 PM   #6
newagecustom
c10 Chop Artist
newagecustom's Avatar
Re: Static or Bags
You should bag that longbed!!
newagecustom is offline   Reply With Quote
Old 09-20-2011, 11:44 PM   #7
ItsRandy
ItsRandy's Avatar
Re: Static or Bags
Static drop. All you gotta' do is blow a bag or air line (even if you have spare parts with you) and you'll be messing up your best clothes and pissing off your wife/girlfriend as she sits along side the road, instead of sitting in a nice restaurant sipping her favorite adult beverage (with an umbrella in it) looking forward to snuggling up to you in the hot new movie that just opened at the local movie theater. Static drop...it's an easy choice.
ItsRandy is offline   Reply With Quote
Old 09-21-2011, 12:00 AM   #8
SCOTI
SCOTI's Avatar
Re: Static or Bags
Build it right & it's not an issue. A crappy built static drop can leave you just as stranded as a crappy built air drop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-21-2011, 09:49 AM   #9
kieth
kieth's Avatar
Re: Static or Bags
I used standard 6 cylinder coils up front, 2.5" drop spindles, and bagged the rear because it is cheap, easy , and adjustable. I made a mistake and got bags that are too big for the rear but will be perfect up front so I will bag the front later and go to the proper 9000 series tapered bag to get the rear ride like it should be. (using too large a bag make you run 20-25lbs of pressure) that is too low, you need to be in the 50psi range to get the ride correct and also pay attention to knowing where you need to be in the middle of the bag (kind of like setting the sag on a motorcycle) a air bag has a height it is supposed to run at, it has a minimum and a max height also....pay attention to these things and you can get it right and not cost a fortune........I have seen the firstone tapered bags for sale for as little as $140.00 per pair, hook them up in place of your rear coils , connect with a schrader valve and at least you can adjust the stance of your truck......without buying 5 sets of coils, or cutting them off to adjust them.
Kieth
Here is how my truck sat before 2.5" drop spindles:
http://kieth.smugmug.com/Trucks/66-G...7_nS2QZT6-A-LB
Here is how it sits with 2.5" spindles and the rear end adjusted low:
http://kieth.smugmug.com/Trucks/66-G...1_9qGFfrc-A-LB
Here is how I have decided to run it now:
http://kieth.smugmug.com/Trucks/66-G..._RGs9Wb7-XL-LB
After getting it to the proper stance and clearance because I have the air bags in the rear it made my look easier to achieve and was not really that expensive, would really have cost less if I had read the threads and got the smaller bags. I will reuse the bags I have now on the front of this truck or another so I am not really out anything but the ability to adjust the rear at will is very nice. Kieth
Here is a shot of the bags and cage I am currently running in the rear, see the comments at the bottom of the picture to see what we are going to do next.
http://kieth.smugmug.com/Trucks/66-G...4_HrvtMh3-A-LB
kieth is offline   Reply With Quote
Old 09-21-2011, 11:59 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Static or Bags
Thats impossible to answer with out more information. We need to know how low you want to go, and what your plans are before we can offer "educated" advice.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-21-2011, 12:29 PM   #11
newagecustom
c10 Chop Artist
Re: Static or Bags
Or maybe i should say "I should bag that longbed" since it's sitting on the trailer in front of my house.
Old 09-21-2011, 12:45 PM   #12
tubbedII
needs more $$$
tubbedII's Avatar
Re: Static or Bags
Haha..figured you knew the guy well...
I vote bag it...as long as you can afford it I can't think of any other reason not to.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-21-2011, 04:15 PM   #13
1971ls1longbed
Re: Static or Bags
its getting bagged
