![]() Join Date: Oct 2009
fuel tank vent?
What is the best way to vent an efi tank? I have a roll over vent valve that came with the tank and the gas cap is vented but doesn't that allow the fuel to evaporate super fast? Do I need to consider an evap canister? Do I even need to install that roll over valve? Tried to find info on this with the "magic google" but can't find much info other than people wanting to sell a tank. I just want to do it right. Thanks for any info...
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
![]() Join Date: Nov 2007
Re: fuel tank vent?
OKG,
I made up this rig using a vent I got at Advance and some brass fittings. I ran it thru the rollover valve which should be open when the shiny side is up. Then I ran a 3/8" hose up high into the space between the bed panel and the fender and mounted it there. Seems to work OK. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
| Bookmarks |
