Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-20-2011, 10:42 PM   #1
ripdog28
ripdog28's Avatar
I love laying under my truck.
Today I wanted to relax so I laid under my truck. And...... Found my brake line rubbing, loose exhaust mount, loose trailing arm u-bolt. It felt a little different the last few days but now I feel a ton better. Just such a good feeling being under it.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 09-21-2011, 06:51 AM   #2
djracer
djracer's Avatar
Re: I love laying under my truck.
Hopefully she will be driving good as new.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-22-2011, 01:30 PM   #3
NCD1966
NCD1966's Avatar
I took a nap under mine a few times, there was a nice breeze out.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 09-22-2011, 05:21 PM   #4
snj8198
snj8198's Avatar
Don't forget about "lock out tag out". Can't have the wife going on a frisky grocery run while you're catching a cat nap under your junk.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-22-2011, 07:58 PM   #5
C-10 simplex
1) i like the fact that i can "lay under" it without jacking it up.
2) Be very careful about laying under your truck in an enclosed area(such as closed garage) near the rear for obvious reasons.
C-10 simplex is offline   Reply With Quote
Old 09-22-2011, 08:18 PM   #6
kcsa75
kcsa75's Avatar
Me too. It's the getting up and down off the floor that's the hard part.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 09-22-2011, 11:31 PM   #7
C-10 simplex
i think wearing shorts helps---the idea is to get as light as possible. Of course, is this the best thing to wear when working on a truck? Probably not.
Cardboard also helps.
Old 09-23-2011, 03:57 AM   #8
ripdog28
ripdog28's Avatar
Oh i can not move around much without it being lifted up. Only about 1/2 in btwn my chest and rear frame. No way i could fit under the front. I commonly wear slippers.. No shorts.
69 c-10 BBC
Old 09-24-2011, 11:35 AM   #9
dan42
dan42's Avatar
with a 2/4 drop my face rubs on things. Gotta get her in the air a little.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-24-2011, 12:11 PM   #10
C-10 simplex
Yes, we are not teen-agers anymore; Not carrying alot of junk in your pockets i think helps too.
Maybe try knee pads which you can get at depot or harbour for cheap.
Slippers and shorts not the best thing for working on the car (even you, Daisy), but you got to do what you got to
do. The shorts really helps with mobility though.
P.S. My uncle has SERIOUS back problems--to the point where he's basically disabled and can't work anymore directly attributed to being a BOP line mechanic (mostly B) for 12 yrs. So this is just something else we need to be aware of.
Actually, this is a very interesting and important topic and i think i would like to start another thread concerning it.
Old 09-24-2011, 12:21 PM   #11
Dunenutt
Newbee
Dunenutt's Avatar
Wanna come over and lay under mine for a while? You can put the tranny and T case back in while you are there. I'm tired of seeing the underside of mine.
Dunenutt is offline   Reply With Quote
Old 09-24-2011, 02:05 PM   #12
Marv D
Registered Truck Offender
Marv D's Avatar
Hey,, another dunes addict Glamis? Headed over there Veterans day weekend for the first trip to see if my new pile of junk can hold up
http://www.small-block-chevy.com/ima.../ricochet1.JPG
But in the meantime.... laying on my back under the truck!!!
I just got the motor back in the 66, and have a oil pump issue (pump shaft is binding on bore in the the rear main once the distributor is in). Managed to get the pan down enough to pull the scraper tray, and then I can get the pump off. Apparently the Little M rear main doesn't like the diameter of the ARP oil pump shaft just before it necks down (stepped shaft for the 400 blocks) it is just enough to say it's not 'right'
WHY didn't I catch this when I was assembling the motor!!!!! Didn't feel anything wrong when it was all going together,, but it's not right,, I can SEE that it's not right now that I have 'felt' the tightness in the pump. Going to chuck the shaft up in a lathe and trim the 'neck down' about 0.030" closer to the pump end so there is clearance.
Is it a Dart problem with the rear main???, or a ARP problem with the position of the neck-down on the shaft???,,, nope, it's MY problem for not checking it before the now!!!!!! I know better. Had a similar issue with the Motown block in the Nova and a Titian pump shaft. Just tight enough that is it WRONG!!!
Laying on my back, under the truck, with the pan only 1/2 way down because it won't clear the chassis and crank to come all the way off is NOT the preferred way to do this task unfortunately!!!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-24-2011, 02:27 PM   #13
BMERDOC
BMERDOC's Avatar
Not tryin to show off but I like to stand under mine if I have some down time at work!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-24-2011, 02:54 PM   #14
Dunenutt
Newbee
Dunenutt's Avatar
[QUOTE=Marv D;4917029]Hey,, another dunes addict Glamis? Headed over there Veterans day weekend for the first trip to see if my new pile of junk can hold up
Nice car! Halloween for us. We will be at glamis.
Old 09-24-2011, 05:24 PM   #15
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Only way I can lay under My '68 is up on jack stands. The price to pay to be low and quick.
BMERDOC I do agree with you, I prefer to stand under mine when I have to chance also.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 09-28-2011, 12:44 PM   #16
C-10 simplex
We're all getting a little older....pt.2 The getting up and down thing:
i think my mom had her first "i've fallen and i can't get up situation!" i wasn't there---i just heard about it. It was in the women's restroom of all places at a restaurant. Normally, she's pretty healthy but i think she was very tired and dizzy from flying all day----my folks went overseas on vacation---which is why i wasn't there and just heard about it.
The cleaning lady couldn't get her up so apparently they had to call my dad to help. Like i said i just head about it and don't know the details and don't really want to know the details..........
So what i'm thinking of doing and suggesting is to just every day when convenient just sit or even lie on the floor, maybe on carboard, and just stand up. Do this 10 times at first. And then maybe 20 and so on and so on. Maybe do it to music---one song on the radio.
It will then probably get easy.
We should really start a new thread.....
