how do I flush my clutch fluid? anyone have a how to?
hey all, ive never changed fluid on a clutch before, wondering what all is involved? i have a 70 chevy c20 with a corporate ho52 rear end but dont know anything about the clutch other than its a 4 speed with one of the gears being granny.
Re: how do I flush by clutch fluid? anyone have a how to?
Are you sure it's a hydraulic system?
A man's thoughts devise his ways; but it's GOD that directs his steps. |
#3 | |
Still plays with trucks
Most times it is a clutch disc that has gotten oil on it from a rear main leak or valve cover / intake leak and it will need replaced. No amount of adjustment will fix it if this is the problem.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
it looks like it has a drain plug on the under side, and there appears to be fluid leaking from the bottom....
#5 | ||
If yes, then yes there is both a drain plug and a fill plug on it. All you need to do is get an 11/16" 8 point socket to fit the square plugs and take them out. Just make sure you take the fill plug out first so you're sure you can fill it back up. Put a pan underneath to catch the old fluid and let it drain out. Once it stops, replace the drain plug and fill it up with plain old 90W gear oil through the fill plug hole until it runs out of the hole, then replace that plug and you're done. That's all there is to it.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
can anyone provide a picture of where the fill plug is? i looked under the truck a while yesterday to no avail
Sorry for the kindergarten artwork, but here's the plug. It's a little less than halfway up on the driver's side.
thanks curt!
