04-12-2003, 05:38 PM | #1 |
Where can I get these gears?
I have run into a problem, my speedometer cable broke, so I am going to replace it. But the speedo has never read correctly in the first place, so I am going to put in the correct gears. I have a np205 t-case and the speedo gears are Stewart Warner on the t-case! I have no part number or anything. My drive gear(s) is 12 tooth and my driven gear is 19. Anyone run into this on their t-cases or is this an aftermarket thing I have? I am willing to swap it out for something stock just as long as I can get what I need to get my speedo working again. Thanks in advance!
04-14-2003, 11:25 PM | #2 |
"Ochre Ogre"
I am going out on a limb here, I think that the transfer case speedo gears are the same. You don't change them to make a change in the speedo reading. There is an adapter that goes between your speedo cable and the transfer case. You should check with a 4x4 shop. They should have a way to figure out what you need. You will need to know what rear end gear ratio you have and your tire size/diameter. From that they can figure out what you need.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
