Old 09-21-2011, 05:24 PM   #1
Dustin07
Stirrer of the Pot
1965 C class vs '62 1/2 ton?
will this bench seat fit correctly in my '62 step?
seems a little pricey. I was thinking of offering $100. then i'll get it upholstered after I finish bags and some other interior stuff.
thoughts?
http://seattle.craigslist.org/tac/pts/2609929414.html
Dustin07 is offline   Reply With Quote
Old 09-21-2011, 05:42 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1965 C class vs '62 1/2 ton?
If you were close, Id give you one.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-21-2011, 05:54 PM   #3
kieth
kieth's Avatar
The seat seems a little high, but one should look and sit on the seat to see how it feels. I spent $500.00 rebuilding my seat on my 66, that does not include any labor. These seats are very weak around perimeter, here is what we did to mine.
1. Replaced all broken springs, sandblasted the frame and all components, painted with silver por 15
2. added seatolators top and bottom (piano wire reinforcing new style) hog ringed it in.
3. Added coarse floor insulation (heavy batting) and hog ringed it into place
4. covered the seat with foam 1" soft foam 2" dense hard foam then glued it on and then shaved it to the proper contours.
5. under the perimeter of the seat we cut long triangles of dense foam (glued black mat type material to is so it would not fall apart)
6. Then we installed a premade vinyl cover in dark gray.
The only reason I went into such detail was so you could see the value of the seat. If it is all firm and nice then it will be easy to recover and use. If is is all loosy goosey then you should purchase it on the cheap.........Kieth
here are some pictures:
just click next to see them (I did not take detailed step by step pictures)
http://kieth.smugmug.com/Trucks/66-G...89634100_Mr3hk
here is a look underneath after we rebuilt the seat base...
http://kieth.smugmug.com/Trucks/66-G...40205255_7tv2t
here you can see the perimeter bolsters and the insulating material before the foam went on. After the foam went on there was so much foam that had to be ground off and it was such a mess I just did not get a picture.
http://kieth.smugmug.com/Trucks/66-G...40205283_jSLVa
here is the seat after we finished it but before we did final installation:
http://kieth.smugmug.com/Trucks/66-G...49354994_W6NaW
kieth is offline   Reply With Quote
Old 09-21-2011, 06:34 PM   #4
Dustin07
Stirrer of the Pot
Thanks Kieth, I was just kinda expecting about $250 for any seat. maybe I should do a little research first. (there is no seat in the truck now).
hey clyde, I was in Austin (ACL) last weekend lol. still not close, but closer...
Old 09-21-2011, 06:39 PM   #5
Surfdaddy
Surfdaddy's Avatar
I spent 180 for the 1961 factory material and 300 for the shop to do it, but it's as close to factory as you can possibly get. You can spend a ton of money on upholstery.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 09-22-2011, 10:32 AM   #6
Clyde65
Clyde65's Avatar
Austin is a fun town, come see us again and bring a truck to get this seat.
Clyde65
Rebuild of Clyde
support our troops!
