tranny cable adjustment
anybody post or step me through on how to adjust the tranny cable..... mine seems to hold in gear a tad too long for my liking and also when I step on the throttle it won't kick down until I practically put my foot through the floor board.... just want the kick down to be looser.... any help
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Re: tranny cable adjustment
We need to know what trans. you have.
If you have a 700R4, DO NOT CHANGE SHIFT POINTS WITH THE TV CABLE! Use the governor to change shift points. You will smoke the 700R4 if the TV cable isn't set correctly.
I learned a lot from reading this. http://www.tvmadeez.com/article/index.php |
TH350............Sorry I didn't include it in my original post
TH350s are as easy as can be to set up.
ENGINE OFF. There is a black tab behind the bracket the TV cable clips into on the intake manifold. Lift it up. With your other hand move the throttle on the carb to wide open throttle. With carb at WOT, push the black tab down. Let go of the throttle. You're done.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
subscribed i have the same issue with my th350
1969 Chevy C10 LWB Its a long bed thing, you wouldnt understand. ![]() |
hey thanks, I will adjust this evening when the temp goes down out....its 100 right now and the truck is parked in the sun
Vintage 4x4s
subscribed
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#9 | |
Subscribed!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
got a picture I took on my phone will post
so are you guys talking about the little clip on the botton metal long bracket..... pull clip of and open throttle, reapply metal flange and put clip back on....that sound right or are you talking about the black piece towards the back on the orange piece
#13 |
That's the one. The tab is on the backside of that orange bracket. Sometimes fun to get at. Push up from the bottom on the cable and the tab should pop up. Open the throttle all the way, hold it there and push the tab back down.
#14 |
Nope. Follow that cable to where it is inserted in that orange bracket towards the back of the intake manifold. Behind where the square piece is inserted is a black tab. That tab is pulled UP, move carb to WOT, push tab back down while still at WOT.
#15 |
Cool, will give it a go this afternoon and post it up tonight..... thanks all
#16 |
Here's a video explaining how.
#17 |
redphone, thanks.... that really helped, I was thinking the entire piece popped up. Did not realize it was a tab...... awsome...
#18 |
its all about the +6 inches
if it still holds the gear a bit too long under normal driving, then you'll probably want to adjust the vacum modulator.
#19 |
where and how do i adjust the modulator....I will try that after I adjust the kick down.... I know for sure the kick down needs adjusting...got to stand on it pretty hard to get her to kick down...so as soon as I can get someone over to put the pedal to the floor I will adjust.... I guess I cam probably do it with my free hand....
#20 |
You can actuate the trottle from under the hood by hand for the cable adjustment.
I would drive it a few days and see what you think. If you still need to adjust the part throttle upshifft, then jack up the truck, locate the modulator, unplug the vac line off of it. Take a flashlight and look in the hose nipple hole. Some are allen wrench, most are flat head screws.... reach in there with what ever tool is needed, screw it in to raise the shift point, out to lower it. Some are not adjustable. If it is not adjustable, then you can get one pretty cheap at a parts store (inspect for adjustability before paying) I have personally never seen one that was not adjustable, but I hear about them suposedly being more common. |
#21 |
so here is the deal.... I got the plastic piece to pop up and was like ok, pushed it back down and when my son got home I went out and asked him to step on the pedal....so I reached back and tried to pull the plastic piece up, it would not come up...my fingers are sore trying to get it popped up and now it is dark.... any ideas
#22 | ||
"I ain't nobody, dork."
Pry it with a small screwdriver. You don't have to have someone step on the gas... just pull the tab up... move the throttle to WOT by hand, and then snap the tab back down.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#23 |
ok thanks.....it pops straight up right.... cause all I did the first time was take both fingers one on each side and lift up and it moved right up but after snapping it back in place I could not get the darn thing to pop back up again...
#24 |
update, got it done and it is working great. shifts spot on and when you are driving around normal and step on it she kicks down great. Thanks all
