Old 09-21-2011, 09:34 PM   #1
samuellg1977
samuellg1977's Avatar
What does this do?
Hello,
Dumb-Question-Guy here again... What does this thing connect to and what does it do? Thanks.
Sam
samuellg1977 is offline   Reply With Quote
Old 09-21-2011, 09:50 PM   #2
awbrown
Re: What does this do?
It is where the "choke stove" as it was called went ,it was a tube that shaped in a "u" that extended in there .. it was heated by the exhaust gases in the passage .. The carb had a small bleed hole that allowed the carb to draw the heated air through the tube to relax the coiled choke spring , there by releasing the choke in due time .. they fell by the way after they started putting electric chokes on the carbs...
Hopefully they included a cover to plug it with ... I have seen them plugged with everything you can imagine ,from silicone to wittled wood plugs..
awbrown is offline   Reply With Quote
Old 09-21-2011, 10:02 PM   #3
samuellg1977
Awbrown,
Nope, no plug... I used the one from my stock manifold to plug it off. Does this connect to the brass nipple that is under the vacuum housing on my Holley? I noticed today that nipple is just sucking air and there is nothing in the tube. I was thinking it is just suckin dirt and crud into my carb, but don't know if i should cap the hole off or if i would damage it if i blocked it off. Any ideas?
Sam
Old 09-21-2011, 10:10 PM   #4
awbrown
With out a picture I cant be sure , but I think you are on the right track .the tube should attach to a round metal unit with 3 screws and have words on it like rich / lean with arrows. The one from the stock manifold should work , just make sure it is not plugged up , that happens a lot with them...
Old 09-21-2011, 10:17 PM   #5
Slow Build
Slow Build's Avatar
Egr ?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-21-2011, 10:24 PM   #6
samuellg1977
I used my compressor to blow it out and then put it in. Man, WHAT A PITA!!!! Next time, i think i will just fill it up with dirt and beat it with a BFH!!! The electric choke on my carb doesn't work, so i am in the process of saving for a new one to replace it. Will it make any difference if i connect this "Choke Stove" to the carb? Anyway, here is a picture of the brass nipple I'm talkin bout...
Old 09-21-2011, 10:29 PM   #7
y5mgisi
Second Chance Program
y5mgisi's Avatar
Like this,
y5mgisi is offline   Reply With Quote
Old 09-21-2011, 10:37 PM   #8
Blue Heeler
Blue Heeler's Avatar
It's a motor locker, that's where you hide your wedding ring. haha
Blue Heeler is offline   Reply With Quote
Old 09-21-2011, 11:00 PM   #9
samuellg1977
Haha... Don't tell my wife that!! I'm already in hot water over this truck!!
Old 09-22-2011, 12:40 AM   #10
tooslo60
tooslo60's Avatar
Super rare factory option under hood ash tray!!
Andy
tooslo60 is offline   Reply With Quote
Old 09-22-2011, 08:34 AM   #11
samuellg1977
Oh, so all thoe holes in my firewall are so I can reach the ash tray in the engine bay. Now, it all makes perfect sense!!
Sam
